Winston
#121
Posted 07 May 2007 - 08:58 PM
They are fantastic little engines with so much potential locked up by the nasty inlet that’s Lotus never designed to use it with and the bottom ends are bullet proof. Over 7k rpm and nothing needs uprating. So much easier than the A series and comes with 5 gears which is fantastic for motorway driving!
#122
Posted 08 May 2007 - 07:18 AM
#123
Posted 08 May 2007 - 08:15 AM
#124
Posted 08 May 2007 - 03:42 PM
Here is progress so far.
#125
Posted 08 May 2007 - 03:46 PM
#126
Posted 08 May 2007 - 04:25 PM
#127
Posted 08 May 2007 - 11:15 PM
As I have the bottom arms and tie rods I saved a bit of money, but the frame, driveshaft’s, bulk head box and gearshift box came to just over £1100.
If you kept the standard injection you may need to move the servo or masters over to the other side
Budget sounds quite good actually i had the frame in my head at £800 and the shafts at £300 so was looking at £1100 before any of the box's or other little things
Im differing from yourself as i idealy would like to keep the standard injection and ecu partly cause i know its generally good at what it does and works fine but mainly cause its also a major saving and my car has no servo so dont need to move that
the only part i cant seem to see a cheap way off doing is getting rid of the disastrous inlet system, the ITB's which your using are the ultimate off course
good luck with the build ill be watching this one closely oh and the cad works looking good, carbon IMO is one of the best materials to make it out of not just due to lightness and strength but also due to heat resistance which id imagine it would be good at?
wayne
#128
Posted 09 May 2007 - 06:58 AM
Tim
#129
Posted 09 May 2007 - 11:39 AM
#130
Posted 09 May 2007 - 06:48 PM
#131
Posted 09 May 2007 - 06:51 PM
only got one copy though!!
#132
#133
Posted 10 May 2007 - 07:14 AM
Tim
#134
Posted 10 May 2007 - 12:59 PM
Matt
#135
Posted 11 May 2007 - 08:06 AM
Then the real fun can begin
