Winston
#166
Posted 05 September 2007 - 09:09 AM
#167
Posted 06 September 2007 - 08:07 PM
I am going on holiday for a week now so rebuild of the subframe will have to wait for next weekend, but hopfully I shall get it all built up then.
Im also stuck at the moment with the front subframes upper arm. The old needel roller bearing won't come out at the moment, even with a blow torch,so i shal have to get the dremel on it as iv got a rebuild kit for it with new axel, bearings and nuts.
#168
Posted 16 September 2007 - 08:04 AM
I managed to rebuild the radius arms with new adjusters, shoes, springs, quadrants, quadrant pins and arms themselfs. The only thing I'm wating for now is the wheels bearing seals ans they have worn through the rubber.
Now that im stuck with the radisu arms like this I thought I would build back up the top arm and have a go again at taking out the bearing from the other arm. Sadly I failed at taking the bearing remains out on one arm even with using heat so im going to have to think about this one. The other top arm on the other hand was simple to build.
So next was the hub. I have bought all new ball joints for it, which after cleaning and painting the hub, I spent an age setting them um perfectly with the shims. I have also managed to get the first new drive shaft in and so thought I would mock up the new brakes
Just cant wait to get them attached to the subframe now!
#169
Posted 16 September 2007 - 08:06 AM
Looks like yer making some nice progress too mate.
#170
Posted 16 September 2007 - 08:18 AM
Yeah Im starting to get somewhere now. Problem is that I go back to uni next week
#171
Posted 16 September 2007 - 10:15 AM
#172
Posted 16 September 2007 - 02:30 PM
The radisu arms are not fully built too and the other side front hub is apart and I'm currently waiting for the paint to dry on it. I hope by mid day tomorrow the rear subframe should be built back up and the front hub should be all built up with brakes and drive shaft and the top arm to be fully built. All im waiting for now is a cone spring compressor
#173
Posted 16 September 2007 - 08:59 PM
Also I have built up the rear subframe ready for it to go back on.
I have come up to a small isure with the brakes. I am using discs and drive flanges used by minisport and have found that the discs foul the hub. Any ideas?
#174
Posted 17 September 2007 - 07:27 AM
Someone else had this issue a few weeks back and, although convinced they were seated properly it eventually turned out they weren't - they are usually a very tight fit. Try using some old wheel nuts and washers to pull them together more?
#175
Posted 17 September 2007 - 01:25 PM
#176
Posted 17 September 2007 - 02:38 PM
I was going to attach the top arms and the hub assemblies to the subframe, but I have found that the Allspeed subframe takes two of the larger washers on the top arm.
No problem thoough as I shall get some later this week.
#177
Posted 17 September 2007 - 07:36 PM
#178
Posted 17 September 2007 - 09:13 PM
keep the gud work!
#179
Posted 17 September 2007 - 09:17 PM
#180
Posted 18 September 2007 - 12:26 PM
Pictures to follow later.
