Winston
#151
Posted 04 July 2007 - 11:47 AM
#152
Posted 04 July 2007 - 06:29 PM
#153
Posted 28 August 2007 - 10:39 AM
Iv set to on the body work. I want it to last a while so decided to strip the shell down and have a good poke around.
I found numerous bodges through the shell and lot's of patches.
First to go was the cross member.
Then the flitch.
In with the new.
Then I turned the shell on its side to get to the sills. Im going to replace both of them with oversills to get onto some decent floor.
I found that one side had an over sill and the other just a normal sill.
I have now cut out the old origional sill behind the over sill to stop any further rust.
There was also a few other bits that seemed to just fall through so out witht he rust.
Next job is a trip to minispares to get some more panels.
#154
Posted 31 August 2007 - 06:54 PM
Didnt realise you had gone for the 16v vaux engine!
Going to have to come see it when its running
#155
Posted 01 September 2007 - 05:34 PM
I’ve picked up my subframe yesterday with bottom arms and tie rods which are all pretty horney. Can’t wait to get the engine mounted in it and the ITB's mocked up. I need to do this to see if I’m going to modify the bulk head for 90mm trumpets. This should gain a bit more power and noise but I’m not sure about them fouling the masters.
#156
Posted 01 September 2007 - 07:53 PM
engine mods...
full rebuild
45mm tapered jenvey throttle bodies with 90 trumpets
steel con rods
forged high comp oversize omega pistons(bored to 1640)
cav gsi calipers, new disks and pads
new rings, cam belt, all gaskets,
19row mocal oil cooler,
ported and ploished head
massive kent cams, 2nd to biggest cams available
titanium valves
double valve springs
lightened and balanced crank and flywheel
4 into 1 manifold
full exhaust system
low temp thermostat
fse adjustable fule pressure gauge
mbe remappable ecu
bigger injectors
sparco strut brace
vernier pulleys
powdercoated rocker cover
went for remapping a couple of months ago and pulled 150 but was burning poo loads of oil and cam belt needs moving to the next tooth but we think it will make about 185-190.
if your going to do it, do it properly
Posted 03 September 2007 - 08:53 PM
#158
Posted 04 September 2007 - 12:33 PM
It's a gorgeous piece of engineering by Mr Rob Hall, with many CAD hours, FEA and testing gone into it to make sure it will last.
As can be seen by the bottom pic it takes rise jointed bottom arms and tie rods. The rose joints on the bottom arms are larger than that of the Minisport ones I have and the fixing method to the tie bar rose joint is different of that from a standard subframe. I think that a minis[pares rose jointed ones would fit if there is enough thread on it.
I also set to on the rear subframe today. Iv taken the bottom arms off as they need new bearings in them. At the same time I shall change the adjuster screws and brake shoes so that I can get them set up properly. I am also cleaning up the Hi-Los and rubber cones. All of which are in good condition.
A lick of paint will come to the subframe before it goes back on.
I also need to strip the front subby to but don't have a cone compressor. Can anyone lend me one?
Also today I cut out big holes in the floor to put my replacement panels in. Iv also cleaned the rest of the floor up ready to under seal. I started welding one floor piece back in but I ran out of gas. I then changed the bottle and ran out of wire. So I think it was trying to tell me something.
Before I ran out of gas though I managed to get the new rear valence on. Its a non genuine one so its a bit of a squiffy fit, but with a bit of tweaking it went on fairly easily.
Iv got a pile of bit of the floor that used to be my car
Iv got a few more little patches to make for the rear of the car but nothing too bad or big.
That’s all for now. Next thing Im going to do is buy some more gas and wire to get the floors on, the sills on and the little patches. Im also going to rebuild the rear subframe ready for it all going back together.
#159
Posted 04 September 2007 - 05:41 PM
that subframe looks awsome. keep going. it will sound awsome!
#160
Posted 04 September 2007 - 06:10 PM
I hope to have most of the rear subframe built back up by teh end of Thursday but we shall see.
Then let the painting begin.
Only problem now is that I can't get the adjuster out of the backing plates as they are both siezed on.
#161
Posted 04 September 2007 - 08:10 PM
2x Reconditioned radius arms.
1x Quadrant
2x Quadrant pins
2x Brake shoe adjusters
2x Rubber cones for the front
#162
Posted 04 September 2007 - 08:25 PM
But you will need a cone compressor to get it back in, even with hilos.
#163
Posted 04 September 2007 - 08:40 PM
#164
Posted 04 September 2007 - 09:01 PM
#165
Posted 04 September 2007 - 09:39 PM
Its amazing the weight of the metal dust taken off the floor.
