#1381
Posted 24 September 2011 - 07:52 PM
#1382
Posted 25 September 2011 - 06:12 PM
S discs do sit close when the proper S hubs arent used, just be careful that the steering arm isnt touching when its all torqued up... once mine wore a groove in a disc, i had to grind back the arm slightly, but proper S arms are available....
keep it up!
Ed
#1383
Posted 25 September 2011 - 06:24 PM
keep it coming
#1384
Posted 26 September 2011 - 07:08 PM
Here's todays update real quick as I need to head out!
Driver side all torqued up and finalised. Need to shorten the bottom leg of that split pin though.
Passenger side. All done but again, split pin needs shortening on one leg.
Tried a wheel on. Might have issue covering these with special arches!
How they sit on the running gear.
And I got the garage cleaned up so I have more room to work with.
Thanks for looking, more tomorrow
Cheers,
Adam
#1385
Posted 26 September 2011 - 07:11 PM
#1386
Posted 26 September 2011 - 07:13 PM
#1387
Posted 27 September 2011 - 06:48 PM
Here's some more:
I'd heard people say that there are some clearance issues when fitting Cooper S calipers to regular disk hubs so I thought I'd do a test fitment before I went any further.
Had to file a small flat on the hub so that the caliper would clear it. The other side already had a machined flat as it's a new hub.
Then all was dandy, no other clearance problems here.
Test fit with a wheel.
At the back.
Close up showing clearance between wheel and caliper.
Next job was to start fitting up the arch protector.
This shows that the arch will hold the protectors outer edge.
Underneath. The liner will be attached to the inner wing with screws to make sure it's not reliant on the plastic arch.
Popped the doors on as they need finishing off too.
Started marking out where they need work.
And the other side.
That was that for the day. First time she's been outside in a long time. Pay no attention to the crow bar!
Thanks for looking
#1388
Posted 27 September 2011 - 06:55 PM
How are you planning to close the gaps on the doors?
#1389
Posted 27 September 2011 - 09:36 PM
I'm going to get it as good as possible by positioning the door and then I'm going to use the trick Neil used on Project Erm, welding thin welding rods in to the gaps to close them up and then dressing neatly with a linishing disk.
It's going to take some time but I can't leave them as they are
Definitely need to get the suspension set up properly when it's all done. The front wheels have some serious positive camber at the moment looks unnerving!
#1390
Posted 27 September 2011 - 09:40 PM
This should help to prevent the rod from bending in thus not needing as much dressing with a block and hammer.
#1391
Posted 27 September 2011 - 09:42 PM
Were they arc welding rods?
#1392
Posted 27 September 2011 - 09:51 PM
Each door took me a day roughly. Be patient with it and you will be pleased with the results. I will defo do it the same way again without a doubt. Too anal maybe but it looks good.
#1393
Posted 27 September 2011 - 10:05 PM
Are arc welding rods just mild steel too or are they not suitable?
I'll do my best to keep it cool. Could do without knackering the skin of the door at this point!
I'm just putting together a small Mini Spares order with some bits I could do with including the odd nut and bolt and some new shims for the doors.
#1394
Posted 28 September 2011 - 08:48 PM
#1395
Posted 28 September 2011 - 11:34 PM
Otherwise I'll have to have a hunt around locally.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
