#1351
Posted 04 September 2011 - 04:44 PM
#1352
Posted 04 September 2011 - 04:50 PM
Looking at your signature, you've got a garage. That's more than I had when I started
Get a project and get stuck in sir!
#1353
Posted 04 September 2011 - 04:53 PM
#1354
Posted 04 September 2011 - 05:22 PM
Plus, I've told myself I'm not allowed to apply for any jobs until Elliot is finished, so I can devote all my time to her.
#1355
Posted 04 September 2011 - 05:51 PM
She will be on the road before the end of 2011. I won't let it roll over in to 2012, I refuse! Haha.
Me and you both then!
#1356
Posted 04 September 2011 - 06:19 PM
#1357
Posted 04 September 2011 - 09:09 PM
#1358
Posted 04 September 2011 - 10:29 PM
I was hoping I could thread it up behind before I bend it all to shape. I'll fit them tomorrow then, cheers for the heads up Graeme
#1359
Posted 05 September 2011 - 08:42 PM
#1360
Posted 05 September 2011 - 10:33 PM
I'm trying to think how I can explain how it works but words are failing me completely.
You've got the opening in the pot which the inner member/ball cage assembly goes inside, which leaves a gap where the grease can escape. The gaitor goes from the outside of the pot to the outside of the inner member. The hole where the driveshaft goes in is sealed like the back of the pot. So the drive shaft doesn't actually come in to contact with the grease, unlike the CV end.
I think they made it like that so it's easy to split from the gearbox without needing to dump the oil or replace the gaitor on the joint. Shame they don't do something similar on the CV end.
#1361
Posted 05 September 2011 - 10:42 PM
I took a few pictures of what I did do.
Driver Side camber arm fitted.
Same on the passenger side.
More tomorrow!
Thanks for looking
#1362
Posted 06 September 2011 - 07:06 AM
Keep at it Deathrow
Hugh
#1363
Posted 07 September 2011 - 07:23 PM
#1364
Posted 07 September 2011 - 09:21 PM
I'm very keen to see it when it's finished!
#1365
Posted 10 September 2011 - 12:50 PM
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
