Elliot - The Second Attempt
roundnose
1658 replies to this topic
#1336 bcjames
bcjames
  • 2,728 posts
Posted 26 August 2011 - 02:32 PM
Painted bits looks great, they'll look awesome on the car.
#1337 analogue_radio
analogue_radio
  • 4,897 posts
Posted 26 August 2011 - 04:18 PM
The paint and detail on those parts are brilliant!
#1338 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 26 August 2011 - 06:05 PM
Cheers guys. I just hope they stay looking like that for at least a bit haha.
Have some more:
Dirty pot joint.
Stripped.
Cleaned.
Back together.
Outer pot cleaned.
Gaitor kit.
Greased up.
Sealed.
Putting shafts in.
Job done.
Just need to do the CV ends on both of those now and they're ready to roll.
Thanks for looking :).
#1339 minimuk
minimuk
  • 1,946 posts
Posted 26 August 2011 - 07:55 PM
nice one just like new,....you kurust those shafts before, didn't you??
#1340 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 26 August 2011 - 08:05 PM
I did indeed.
Took them down to bare metal with the wire wheel on the grinder, kurust, sanded, etched, primed and then top coat.
Need to sand the paint a bit where the CV boot is going to sit before I put the new CV's on then they're ready to go back on the car :).
#1341 GraemeC
GraemeC
  • 7,435 posts
Posted 27 August 2011 - 03:47 PM
Before you go putting the outer CVs on, rememeber that you have to pass them through the subframe!
If they're fully assembled you won't get them through the holes.
#1342 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 27 August 2011 - 05:08 PM
Really?!
I thought the holes in the subframe were plenty big enough for the pot joints to fit through?
I'll probably knock the pot joints back off as they're sealed and easy to refit. I want the CV's sealed up when they go back to the garage so they don't get contaminated with crap haha.
#1343 grahama
grahama
  • 2,442 posts
Posted 27 August 2011 - 05:12 PM
Fantastic work !!
#1344 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 27 August 2011 - 06:15 PM
With Graham on this - fantastic work. Deathrow has always been my hero.
Hugh
#1345 GraemeC
GraemeC
  • 7,435 posts
Posted 27 August 2011 - 07:46 PM
I think they just squeeze through with no gaiter - certainly not when built up fully.
#1346 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 27 August 2011 - 08:36 PM
What's the best way for it all to go back together then? Should I knock the pots back off and attach them to the gearbox when it's finished instead? Or is it easier to put the pots back on the gearbox when I drop it back in to the car?
#1347 minimuk
minimuk
  • 1,946 posts
Posted 27 August 2011 - 08:43 PM
That's what I would do, you have more control over the shaft to putt trough the subby preventing scratching the nice paint.
you use Shloer??
Edited by minimuk, 27 August 2011 - 08:46 PM.
#1348 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 27 August 2011 - 08:51 PM
I drink it sometimes. I'm using the bottle as a used white spirit holder.
#1349 minimuk
minimuk
  • 1,946 posts
Posted 27 August 2011 - 09:47 PM
sure you are,...I will have a go at my old drive shafts(1968), see if I can Match yours,.....probably not but who knows.
#1350 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 04 September 2011 - 04:38 PM
An update?! Not had one of them in a while!
Took a bit of material off the outside of an old bearing race. I'm going to use this to drift in the new races.
All the parts that need to get put together.
Steering rack installed.
You can see why I wrapped the subframe up.
Unwrapped.
Passenger side upper suspension arm fitted along with the rubber doughnut and hi-lo.
Same done for the driver side.
Subframe moved out of the way again for the time being.
Knackered now and I stink of white spirit and cavity wax so I'm going to go get a shower. I shall plod on again tomorrow as I really enjoyed today.
