Elliot - The Second Attempt
roundnose
1658 replies to this topic
#1321 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 22 July 2011 - 01:07 PM
Well I've mostly finished sorting my room at home out so I now have the space to rebuild my upper arms, hubs and drive shafts in a clean environment.
All tidy (sort of).
I'll head to the garage later today and get some snaps of the dried paint, see how it's come out. I'll also bring home all the stuff I need to rebuild the parts I need to do at home. Regular progress should resume tomorrow.
Thanks for looking :).
#1322 liam_italian
liam_italian
  • 1,417 posts
Posted 22 July 2011 - 02:06 PM
Wow I really need to sit down with a fresh pot of tea and read this entire thread, its huge.
You've done some brilliant work on this, If I was wearing a hat I'd take it off to you!
#1323 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 25 July 2011 - 07:16 PM
Cheers, I'm glad you're enjoying the read.
I'll be doing an update in a few mins.
#1324 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 25 July 2011 - 07:29 PM
Decided it was time I got on with rebuilding these parts for the front end so that I can get Elliot on her wheels again. I decided to start with the upper arms. I also had to pop out to buy some stuff, hence why there isn't a massive amount done.
Inside of upper arms cleaned out and a smear of grease applied.
Rebuild kit from Mini Spares, it comes with the plate for the front of the pin too.
I set the pin up like this which allowed me to pull the bearings in most of the way.
Tightening the bolts, sliding the bearings in to place.
Used that method up to about this point.
Then I finished them off with a hammer and drift.
Whacked the seals on the ends and reinstalled the grease nipples after I'd cleaned them out with fresh grease and there we are.
I've squirted a little grease in to them both to keep them happy for now. I'll grease them properly when they're back on the car.
I'm poping round a friends tonight but if it's not too late when I get back, I might make a start on doing the ball joints.
Thanks for looking :thumbsup:.
#1325 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 29 July 2011 - 12:54 PM
That's a very good tip, when i did mine i just put them in the vice, but this way get's them in nice and square.
#1326 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 01 August 2011 - 10:25 PM
Yeah it works alright! Haynes says to use a vice but my vice has been snapped and welded back together so I'm not sure the jaws are perfectly parallel.
#1327 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 01 August 2011 - 10:29 PM
I don't mean to scare anyone but...
...I've done some work!
Started sorting these bottom arm pins out.
While I was waiting for some etch primer to dry.
Then I applied some red oxide to these parts.
Finished removing the old bushes from the bottom arm pins.
Lip was clamped in place and then held in place with screws.
Bonnet popped on.
And trim screwed in place.
It doesn't sit quite right just yet but I'll sort that tomorrow when I finish it off!
Waiting on a few bits from Mini Spares before I can get on with my hubs.
#1328 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 02 August 2011 - 05:25 PM
Got the bonnet lip repair finished off today.
Put the bonnet back on its hinges (what a faff).
Trim piece sits nice.
Cleaned down the welds.
Also cleaned these up ready for primer and paint.
#1329 ajperry
ajperry
  • 316 posts
  • Local Club: Thames Valley Mini Club
Posted 05 August 2011 - 09:35 PM
looking good dude! frankensteins Elliot is coming together nicely! :closed:
#1330 jayjay31
jayjay31
  • 108 posts
Posted 10 August 2011 - 10:56 PM
great post i be following some of your pointers
#1331 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 12 August 2011 - 05:26 PM
Thanks for the comments guys!
Not been any progress of late, having some problems with doing the ball joints and the last few days I've been sorting the TMF upgrade.
I'm sure MITP will be the enthusiasm kick up the bottom I really need ;).
#1332 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 23 August 2011 - 06:30 PM
Never fear all, although there are no pictures, stuff is going on in the background but it's boring stuff no one really needs to see haha. I shall update you all before long!
#1333 jeddixon
jeddixon
    Starting My Mini Up
  • 2 posts
Posted 24 August 2011 - 02:41 PM
hi read the whole tread loved it ! I am in the middle of an restoration on my 1986 Austin mini needs the about the same amount of wielding and work but I look forward to see your mini with a lick of primer !
#1334 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 26 August 2011 - 02:22 PM
I'm glad you've enjoyed reading it! I've enjoyed writing it, even if it's taken way longer than I originally intended it to haha. You shouldn't have to wait too long to see that now hopefully :).
#1335 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 26 August 2011 - 02:26 PM
As I said earlier, bits and bobs have been going on in the background but they didn't really warrent a big update. Here's some progress on what I've been doing:
Batch of parts I've painted.
A close up.
And another.
Last one.
I've done more than that but I don't have any imagery for it. I'll take some more pictures as I progress today and keep you all in the loop.
