Elliot - The Second Attempt
roundnose
1658 replies to this topic
#1246 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 18 June 2011 - 10:12 AM
Hi,
subframe came up well, is that just wire brush work or some sort of cleaner too?? Also what are you doing brakes wise if the 8.4's aren't going back on??
Graham
Combination of a bit of wire wool, wire brush, grinder with a wire wheel and a wire brush in the drill. I'm going to use some degreaser on it today to finish it off before I kurust the nasty bits.
Since it was a looooong time ago, I'll forgive you :):
#1247 tedmcedd
tedmcedd
  • 2,751 posts
Posted 18 June 2011 - 02:54 PM
cool man! coming together!! proper AP calipers too! nice!
#1248 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 19 June 2011 - 12:10 AM
They won't be staying that colour though >_<.
Here is todays stuff:
Subframe ready for degreasing.
Degreaser applied.
Pressure washed off.
Reapplied seam sealer where it was damaged by welding.
And the other side.
Etch primed the subframe. I did kurust it also, but I forgot to take pictures.
Rubbed down and wiped down ready for another primer coat.
Primer applied.
Good coverage under the wings.
Subframe got the same treatment.
How I left it for the day.
Going to go round again tomorrow and get the top coat put on. Will no doubt start work on some other bits and bobs while I'm there too.
Thanks for looking >_<.
#1249 grahama
grahama
  • 2,442 posts
Posted 19 June 2011 - 09:40 AM
Hi,
take it you are spraying your red oxide, (if it is ) ?? Have you a compressor or electric spray gun or is it just loads of rattle cans??
Looking good though.
Graham
ps, 1 in the morning posting !! you need to lay off the red bull, lol !!
Edited by grahama, 19 June 2011 - 09:42 AM.
#1250 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 19 June 2011 - 01:01 PM
It is indeed red oxide, get it from Focus. I'm using a spray gun and a compressor.
Hey, I got back from the garage at 9:30PM yesterday! It'll do that to you >_<.
#1251 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 20 June 2011 - 12:47 AM
I wanted to get the stuff I primed yesterday in top coat today but the primer wasn't quite dry on the bulkhead so I left it for now. I did sort out the subframe though.
Primer rubbed down.
Wiped down ready for paint.
Painted.
I started to work on the steering rack but didn't get very far. The gaitors are split, but I already bought new ones. I was going to renew the track rod ends but looking at them, they still have alot of their original paint on them, they don't have any slop in them and the rubbers are fine so they can stay. I do need to work on getting them off though so I can replace the gaitors and refurb the rack.
Won't be any work tomorrow as I'm going to a workshop at Uni.
Thanks for looking :errr:.
#1252 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 25 June 2011 - 11:15 AM
Made some progress the last few days:
These are the pins from the upper arms, neither are great so I'll probably rebuild both arms.
Cleaned down of all rust.
I didn't want kurust getting in to the shaft and making the bearings harder to remove so I masked them up.
Kurusted them and you can see the steering rack in the background too.
Bulkhead ready for paint.
Painted bulkhead.
Driver side inner wing.
Passenger side inner wing.
Underneath.
The other side.
Remainder of the subframe.
As you can see, there are a few harder to reach areas that I've missed so I'll probably do some touch ups on it when I do the interior floor and boot.
Thanks for looking :lol:.
#1253 chrisandsarah
chrisandsarah
  • 747 posts
Posted 25 June 2011 - 04:24 PM
I need to take off some surface rust off my rear subframe for MOT + piece of mind.
What did you do exactly
Your removed it
Degreased + hosed
Kurusted - just paint it on and leave it????
etch primed
primered
then painted with what??
You are a pro! So I thought I would ask :) thank you!!!!
#1254 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 26 June 2011 - 11:30 AM
Your removed it
Degreased + hosed
etch primed
primered
Yeah that's it pretty much, the paint I used is Rustoleum.
You could have it sand blasted and powder coated for ease if you liked though.
#1255 chrisandsarah
chrisandsarah
  • 747 posts
Posted 26 June 2011 - 12:29 PM
Is sandblasting and powdercoating as good? Surely its easily scatched?
#1256 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 26 June 2011 - 12:53 PM
It's more robust. But once it's cracked, it's buggered as stuff can get under it.
It's alot harder to damage than paint though. Rustoleum is pretty hardy once it's dry but it does take a while to dry properly.
#1257 chrisandsarah
chrisandsarah
  • 747 posts
Posted 26 June 2011 - 01:46 PM
I think I will just copy you! :) Cheers for the info!
#1258 tedmcedd
tedmcedd
  • 2,751 posts
Posted 26 June 2011 - 07:30 PM
nice work dude! :)
#1259 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 26 June 2011 - 09:06 PM
I've just spent £240 on Mini Spares...
:P
Should be the last big lot of stuff though! :)
#1260 Simon@minispares.com
    Minispares
  • Minispares
  • 3,253 posts
  • Name: Simon Jackson
Posted 28 June 2011 - 08:02 AM
:D
Should be the last big lot of stuff though! :D
Famous last words!
