Elliot - The Second Attempt
roundnose
1658 replies to this topic
#1231 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 11 June 2011 - 06:14 PM
It's getting closer! Looks good, I've watched this from the start and although it's taken a couple of years the quality of the repairs really looks spot on. It should last a long time. :(
Thanks Austin!
It wouldn't have taken so long if it wasn't for University and girlfriends haha. Oh well, life is for living!
I do really hope you're right and it lasts me a good few years before I need to do any additional bodywork, should do though :(.
While I'm here, I just want to say thankyou to Mini Spares, they supplied me with the replacement bumper lip completely free of charge. Another thankyou to Simon for making that happen and for just generally being a great help to me. Don't put your feet up yet though Simon, still a ways to go :).
#1232 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 13 June 2011 - 06:57 PM
Been to the garage today:
Bumper lip now held in the correct place ready for welding.
Turned my attention to the front subframe.
Removed the passenger side split pin and got the breaker bar on there.
Came off with minimal effort.
The other side was a different story. I couldn't find anyway to hold it solid enough to undo it so:
Dropped the body back on to the frame.
Came off a treat then.
Got the body back up and supported.
Started taking the passenger side running gear to bits.
Driveshaft whipped out.
Didn't get chance to start on the other side.
Frame looking a bit more bare. Needs a bit more work yet though.
Welding wire arrived today while I was out so there will be some proper progress tomorrow.
Thanks for looking :thumbsup:.
#1233 analogue_radio
analogue_radio
  • 4,897 posts
Posted 13 June 2011 - 08:57 PM
Looking so good man!
#1234 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 13 June 2011 - 09:32 PM
It's getting there, slowly but surely.
I just hope it's not too slow for MITP!
#1235 Mini-Mad-Craig
Posted 14 June 2011 - 12:44 AM
My life now has such little meaning that I sat down with a flask full of tea at 9pm and have just finished reading your thread. Some awesome work went on, very impressive gearbox rebuild, too. Keep at it because it'll be real worth it in the end :thumbsup:
Bedtime. :-
#1236 chrisandsarah
chrisandsarah
  • 747 posts
Posted 14 June 2011 - 04:23 AM
Started reading the thread at midnight - just finished - 5.22am. Great read though! Feels like a story that has built up to a climax.... the paint :thumbsup:
So much info! Cannot wait for updates!
#1237 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 14 June 2011 - 07:11 PM
Thanks for the kind words you guys. Really glad you enjoyed reading through :).
Here's todays stuff:
Started to get the bumper lip welded in place.
Getting there.
All welded up.
I also took this oppertunity to add a few more slugs of weld in a few places that I felt needed it. On the rear of the a-panels and on the wing to front panel seams.
Welds ground back and cleaned up.
Overall view.
When I was inspecting my new camber brackets before I started to prep them for paint I noticed there was a random blob of weld on one of them which would stop it sitting against the rear subframe correctly.
The offending blob of weld.
Ground off and linished smooth.
Still trying to finalise another Mini Spares order for the bits I need to rebuild the front subframe. I also need to order some high temperature paint for the Cooper S calipers.
Thanks for looking, should be more updates tomorrow :gimme:.
#1238 tedmcedd
tedmcedd
  • 2,751 posts
Posted 14 June 2011 - 09:37 PM
Pow Pow Pow!!
nice one man!
what wheels do you have again?? exactions?
Ed
#1239 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 14 June 2011 - 09:40 PM
Pow Pow Pow!!
nice one man!
Ed
Ohhhh yeeeahhhh.
Can't wait to have them in black and fitted :).
#1240 grahama
grahama
  • 2,442 posts
Posted 14 June 2011 - 09:53 PM
Fantastic work as ever matey, catching u up though !!
Graham
#1241 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 15 June 2011 - 07:04 AM
Hey Graham lets be honest - we'll never catch him up!! He is our inspiration and our master!!! Great to see this moving along. Thanks again Deathrow for making this information available to us. I used to read your post anonymously thinking I could never do that! I was just so impressed. That sounds bad - still am most impressed!! Keep up the great work.
Hugh
#1242 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 17 June 2011 - 12:04 AM
Hugh
Cheers Hugh, but I wouldn't call me a master! The work of others on this forum is always what inspires me to have a go and then better my work :).
Been to the garage the past few days but it seems I'm putting alot of effort in and not really getting anywhere :). I'm hoping I can make a change to that pattern tomorrow and get some proper work done.
Anyway, here are the pictures:
Got the holes drilled for the front plate. It looks wonky because the holes in the plate were drilled in the wrong place by whoever fitted it before me. I'll replace it at some point.
Had to grind a bit of metal away here in order to provide clearance for the spot brackets on my grille.
Om nom nom.
The mounting holes for the grille didn't quite tally with each other and they were slightly to one side. So welded them up.
Neatly.
Dressed the weld.
Redrilled the holes where they should have been (I was probably just being picky, but I'm like that!).
I then set about stripping the remainder of the front subframe down.
Bottom arm bushes were seized on the shaft so I had to cut the end of the bush and persuade the arm off the rubber instead.
Those sleeves are going to be a joy to remove.
Then I began dismantling the other hub and found...
Great. I'm relatively sure that means this CV is scrap. £30.
And the other side. Super, that's £60 then and I imagine I'll need to do both sets of bearings too, £160 :D.
Just when you think you've replaced every part imaginable, she throws more scrap at me. I'll be asking in technical about those shafts and if they're reusable. I'll pull the bearings as soon as my new punch set shows up and check them out.
Thanks for looking :D.
#1243 daveeeeee
daveeeeee
  • 684 posts
Posted 17 June 2011 - 09:22 PM
unlucky on the parts mate :) good progress though!
#1244 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 17 June 2011 - 10:02 PM
These things happen ;). Oh well!
Cleaned these seams up a bit more.
Checked that the seam covers still fit.
Protected until I'm ready to paint.
While cleaning up the seams I had to do a bit of welding here and there so some of the seam sealer got burnt.
Dug out and primed.
Same on the other side.
Then I started work cleaning up the front subframe.
Underside before.
Underside after.
Front before.
Front after.
Back before.
Back after.
Ready to be degreased.
I was trying to degrease it by wiping it all down with white spirit but it's just too complex a shape to get at it all. I'm going to go and buy a tin of gunk tomorrow and go to town on it then I'll pressure wash it and dry it with an air line.
Started stripping down the driver side hub.
Brakes off.
The old setup, won't be going back on.
Tomorrow I'm going to work towards getting the subframe cleaned and in primer as well as re-priming under the front wings and the engine bay.
Thanks for looking :-.
#1245 grahama
grahama
  • 2,442 posts
Posted 18 June 2011 - 07:35 AM
Hi,
subframe came up well, is that just wire brush work or some sort of cleaner too?? Also what are you doing brakes wise if the 8.4's aren't going back on??
Graham
