#106
Posted 09 February 2009 - 08:47 PM
#107
Posted 10 February 2009 - 12:38 AM
Thanks for your help minivanman, and you tedmcedd.
With any luck I'll be heading to the garage on Wednesday and getting some work done.
#108
Posted 10 February 2009 - 06:46 PM
i also agree with no servo, they do take up too much room! lol
#109
Posted 10 February 2009 - 08:07 PM
#110
Posted 10 February 2009 - 08:24 PM
#111
Posted 10 February 2009 - 09:41 PM
#112
Posted 27 February 2009 - 06:34 PM
Rusty hole in driver door step.
Rusty hole cut out.
Top of jacking point painted with rustoleum.
Section cut from a door step repair panel and welded in place.
Welds roughly dressed.
Now my issue is the fact the door step repair panel didn't match the profile of my step entirely, so I tried to persuade it to but as you can see the fold where the panel bends up to spot to the inner sill isn't quite as good on the repair section as it is on the original panel. Now I can't decide if I'm happy with this or not, as it stands it's going to need a good skim of filler, but I'm not sure I'm happy with that.
My other option is to cut the door step off the shell I have spare (has no ID so it's effectively waste) and replace most of the length of the door step (including another rusty hole I have yet to patch further along the step), correcting the profiling with a genuine panel off another car.
What do you guys think?
In other news, I picked up a set of 5 Exacton alloy wheels from GrameC (thanks for that mate
I've got three weeks of Uni left this term and then I have a month off, which is when I shall really get cracking with Elliot, no messing
Keep watching guys.
Edited by Deathrow, 27 February 2009 - 06:38 PM.
#113
Posted 01 March 2009 - 06:25 PM
#114
Posted 01 March 2009 - 06:27 PM
#115
Posted 01 March 2009 - 06:41 PM
#116
Posted 01 March 2009 - 07:35 PM
#117
Posted 01 March 2009 - 07:46 PM
I'd say re-do the patch rather than remove a load of good metal.
#118
Posted 01 March 2009 - 09:06 PM
Should be heading to the garage this coming Saturday, with a helper in fact! Should get some work done with a bit of luckwaiting for the next update fella
Thanks chap, I know what you mean, I used to get that alot but once you get a knack to it they appear much less frequently.Your welding is good for gasless. Mine always ended up all holey after trying to grind them down.
The space between where this repair ends and the next would start is only about 2 inches, is it really worth it to save that much original metal? It would also provide better access to clean up the jacking support. Decisions, decisions!
I'm currently trying to mock up the sticker I want to get made for the rearquaters (a bit early I know, but I've nothing better to do at Uni haha). Does anyone know what font the original Mayfair writing is in? The script one.
Thanks for the comments guys
#119
Posted 15 March 2009 - 07:51 PM
Here are Elliots new wheels:
Wheel one, I've started sanding this one back already.
Wheel two.
Wheel three.
Wheel four, this might be repairable but I didn't feel comfortable using it so I sourced another.
Replacement wheel four.
I'll either be sand blasting these myself and starting the refurb or I'll take them to be sand blasted, then start refurbing, we shall see, no rush just yet.
This is Elliots new engine which I bought off Jordie a month or so back, I'm going to start collecting the bits and bobs I need to finish this off as I go. I'd like about 90bhp from it, but we shall have to see. According to GuessWorks' engine number lookup on his site, this engine is from a Cooper RSP, if this is correct, it should be a pretty decent starting block
That's all guys, I've got a week left and then I have a month off. I'm going to put in some serious time on Elliot in that month, basically every day of the week the weather will allow me
Thanks for looking.
Edited by Deathrow, 15 March 2009 - 07:53 PM.
#120
Posted 15 March 2009 - 08:03 PM
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
