#1051
Posted 30 September 2010 - 10:30 AM
#1052
Posted 30 September 2010 - 04:59 PM
Face your fears Ednice one! could do with measuring the minus out... i dont think i dare though!!
Should be alright though, no rot to deal with so it should have remained straight.
its wheather the guy who built it measured and drilled it properly
looking good chap!
#1053
Posted 30 September 2010 - 09:59 PM
First task of the day was to take this...
...and these...
...and make this.
Drilled and primed.
Held in place.
View from outside.
Welded up, not quite finished but not much left to do before I can grind the welds back neat.
I'm moving back to my Uni house tomorrow, so I won't be working on the car. Should have an update on Saturday though so check back
Thanks for looking
#1054
Posted 01 October 2010 - 05:33 AM
Remember lots of pics as I am using your build as a 'how to' guide !! So any mistakes and I will be knocking on your door
regards,
Graham
#1055
Posted 15 October 2010 - 10:39 AM
Anyway, managed to get to the garage for a few hours yesterday so here are the pictures:
Updated to do list.
Since no alignment changes could be made any more, I decided to take the front off its stands and support the rear properly.
Done.
Finished up the welding on the closing panel.
From the side.
Checked the arch still fits properly.
Welds dressed and a quick dusting of zinc rich primer applied to protect it.
There is still some weld dressing to be done inside the car before I can call it done, but the welding is finished in this area.
I've fallen back upon the old cellulose vs rustoleum debate again, primarily because money is a bit tighter than I would have liked due to some people pulling out on some jobs I was supposed to be doing. I better decide quick!
Thanks for looking
#1056
Posted 15 October 2010 - 03:34 PM
#1057
Posted 15 October 2010 - 05:40 PM
I'm just worried about the temperature Pete
#1058
Posted 15 October 2010 - 05:47 PM
I've followed your thread recently, being amazingly impressed at the work that you're putting in to the car. Yours is one of the project threads on here that have really inspired me to learn to weld and fix my mini for myself.
However, I've not been well these last 2 days and this afternoon I decided to read your thread through from the start and I admire every inch of work you've done to Elliot - I really am impressed and just hope that I can show the same dedication to Reggie that you have shown here.
Keep up the amazing work - You're a true inspiration - Thanks
#1059
Posted 16 October 2010 - 10:16 AM
There are some bits here and there that if I were to do them again, I'd do them differently, but that's how you learn isn't it. At the end of the day, there are so many panels available for the Mini, if the worst happens and it goes a bit wrong, you can replace the whole panel.
I'm quite excited for her to be finished, just need to get over the final little bits of welding/grinding and get her in paint. Then winter can be used to piece all the mechanicals back together
Hope you're feeling better as well Bean, I've got a cold at the moment, it was going away until I went and worked on Elliot on Thursday, then it got worse again
#1060
Posted 16 October 2010 - 10:27 AM
Ed
#1061
Posted 18 October 2010 - 03:37 PM
Yeah, I'm fine now, thank you - Think I've been over-doing it lately!
I totally agree!
Keep it up, Mr!
#1062
Posted 18 October 2010 - 03:54 PM
keep up the good work mate
#1063
Posted 21 October 2010 - 06:15 AM
I shall have to have a read back through sometime soon, I've been feeling a bit down about the project (think its fear that the alignment of the rear subframe won't be right) even though it's so close to being finished.
Plan is to go and carry on with her today once I've done my lectures and played squash, the weather is looking grim though so I'll have to wrap up.
Maybe some progress later.
#1064
Posted 21 October 2010 - 07:20 AM
Keep it up!
#1065
Posted 22 October 2010 - 04:33 PM
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
