Elliot - The Second Attempt
roundnose
1658 replies to this topic
#1021 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 09 September 2010 - 05:49 PM
Had a good day today!
Subframe offered up for a final check and some measurements.
Bolted up on the driver side.
Alignment on the passenger side, spot on.
Subframe removed, the primer I used on this from halfords has been rubbish, the top coat keeps peeling off. I'll probably end up stripping alot of this back and using red oxide, a primer I trust, before painting it up again, this time with the spray gun instead of a brush. In fact, once the bodywork is done, I might sling both the front and rear subframes to the sandblasters and do the job properly.
This is my new thing I'm doing. I have a notepad at the garage and I write down all the things I want to get done that day, this means I don't find myself faffing about thinking about what to do next, I just have clear instructions to follow. It seems to make me alot more productive.
I readied the tools.
Did some cutting and grinding.
Because the other hammer wasn'y big enough :-.
Part way through chopping.
Majority cut out. There are still some bits I need to grind down and I need to remove the spot welds on the seat base and in the companion bin.
More tomorrow, got a good bit of enthusiasm going now.
Thanks for looking :trooper:.
#1022 tedmcedd
tedmcedd
  • 2,751 posts
Posted 10 September 2010 - 06:01 PM
persuasion hammers always win! hahahaa! nice work! glad it all lines up!! gonna be a jobe well done me thinks!!
Ed
#1023 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 10 September 2010 - 07:13 PM
Ed
Cheers Ed :thumbsup:.
Would have got more done today but I had a migrane late last night and it's knocked me off balance a bit through lack of sleep and stuff so I took the day off. If I'm feeling better in the morning I'll go get some work done tomorrow.
#1024 theminx277
theminx277
  • 12 posts
  • Local Club: Was CV1 MINIS...
Posted 12 September 2010 - 07:10 PM
Saw some of the photos - some reason my computer wouldnt show the last photos - but i hope the bootlids ok for you! Sarah.
#1025 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 12 September 2010 - 07:39 PM
Thanks Sarah, I look forward to recieving it.
I couldn't stand the thought that after all this work the really badly fitting boot lid I had was going to let it all down so I needed to sort out a new one, cheers for that :lol:.
#1026 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 16 September 2010 - 09:04 PM
Righto! Been feeling a bit better the last few days so I've slowly but surely eased back in to working on Elliot. This is the progress from the last few days:
Oh doesn't that look yummy!
Not anymore!
But alas, Elliot always has some more rust she's been saving for me. Are these thick plates neccesary? Can I leave them off after I've repaired the steel underneath them?
Lip repaired, again. Nevermind the purple, it's only Kurust.
All bad steel now removed.
Started making the sections to replace the steel I removed. I've also done card templates for the floor/sill but they're not pictured.
My replacement boot lid should arrive tomorrow, then I'm back off to the garage for some more work!
Thanks for looking :).
#1027 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 19 September 2010 - 11:16 PM
Here's some more work from the end of last week.
To start with I wanted to perform an experiment to see which underseal is going to be best to use on the underside of the car in the wheel arches and stuff like that.
Chopped out two small panels out of thin metal and primed half of each one.
One sprayed with hammerite underbody seal with added waxoyl.
The other with this brush on stuff from my local motorfactors.
I let them dry, put a gouge in the middle of them to try and simulate some trauma such as a stone chip or the like. I've left them out on the garage roof to see what the weather can do to them. I've left the rear of the panels bare metal so that it'll be clear to see when rust really sets in and how the underseal performs. The tetroseal stuff was alot harder to damage though so I'm imagining that is going to fair the best. Time will tell.
Kurusted areas were rubbed down and primed.
Started fabricating repair panels.
Got subframe in place to see how the repair panels would fit.
Lips folded for plug welding.
Welded this repair in, not the best looking repair but no one will see it.
Then I trimmed the plug welding tabs down too much like a lemon so had to weld them back on.
I'm going to go and do some more work tomorrow so keep an eye out :).
#1028 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 20 September 2010 - 06:37 AM
Some nice progress going on here. Takes me back a while although I think I got off quite lucky with my shell. Also makes me realise how valuable the spit was.
Re the underseal. Have you thought about using proper stonechip?
Much easier to put on and you can then paint over it.
Maybe worth thinking about.
Regards
Steve
#1029 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 20 September 2010 - 11:34 AM
Cheers Steve.
I've no need to paint over it as the car is going to be black, plus I wanted something that has an oily base in order to help repel rust and water.
#1030 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 20 September 2010 - 08:07 PM
No rest for the wicked!
Finished amending my mistakes.
While the primer was drying I did some more work neatening up the rear end, mainly on the bumper lip and rear valance.
Another angle.
Time to start filling this in.
Panels tacked in place.
Additional patch needed.
All welded up :D.
More tomorrow, thanks for looking :D.
#1031 tedmcedd
tedmcedd
  • 2,751 posts
Posted 20 September 2010 - 08:15 PM
yey! looks tres bon! nearly done!!??
Ed
#1032 minimaff
minimaff
  • 695 posts
  • Local Club: Barnsley mini club
Posted 20 September 2010 - 08:17 PM
Looking good, keep it up !!
#1033 1984mini25
1984mini25
  • 8,785 posts
Posted 20 September 2010 - 08:19 PM
Looking good as always.
I’ve always used the hammerite version of the tinned underseal; just hate painting the stuff on, as it’s rather messy.
Although I’ve recently picked up a few cans (£2.50 each :D ) of spray underseal to do all the nooks and crannies for when I re-do the underside of all the bits a brush simply won’t get to.
I’ll see how long it lasts, but the last lot of underseal was done about 5 years ago and the only rusty bits I have were rusty before hand, so has probably helped slow it down if anything.
#1034 ajperry
ajperry
  • 316 posts
  • Local Club: Thames Valley Mini Club
Posted 21 September 2010 - 09:51 AM
looks great man! coming on fast now... the welding seems neverending! haha keep going dude it'll all be worth it! also be really interesting to see which underseal performs best. :D
#1035 Mike Delaney
Mike Delaney
  • 25 posts
Posted 22 September 2010 - 02:10 AM
I just spent the last two evenings reading about your Mini. You have progressed nicely through out the build. The welding and panel fitting have been a joy to watch as you got more comfortable with it. Now I know the problem areas to look for when I bring my Mini home at the end of October. It has been a great read and can't wait for thr next installment.
Mike
