Elliot - The Second Attempt
roundnose
1658 replies to this topic
#931 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 10 August 2010 - 09:25 PM
Cheers Luke :P. Done some more today:
Finished neatening up the seams on the wings and seam sealed.
Passenger side.
Removed the bracket off the bulkhead brace.
A worthwhile move I feel!
Cleaned up the bulkhead.
And the bracket.
Kurust applied to bulkhead.
And the bracket.
I think the best way to go about putting it back on is if I finish prepping the remainder of the bulkhead, etch and prime and then weld the brackets back on before the remaining coats of primer. Once it's back on I'll seam seal it to prevent this ever happening again.
First job tomorrow is to remove the steering rack bracket and do a similar procedure on that.
Thanks for looking :P.
#932 tedmcedd
tedmcedd
  • 2,751 posts
Posted 10 August 2010 - 10:33 PM
You really are going all out!!! glad i dont have to do this to get a rust free finish :P hahahaaa!!!
#933 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 10 August 2010 - 10:35 PM
I don't think I'll bother next time :P
#934 CLM
CLM
  • 817 posts
Posted 10 August 2010 - 11:58 PM
lol this isnt bad, my plans when I get home are a bit more extreme, I have to open up most all boxed sections to take care of rust... hopefully I can get some pictures.
Chris
#935 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 11 August 2010 - 08:19 PM
More:
Steering rack bracket removed.
Grotty.
Bulkhead quickly cleaned up.
Took longer than I expected to remove the bracket. More progress tomorrow. I'd like to get the bulkhead and under the wings in their first coat of primer before I come home.
Thanks for looking >_<.
#936 Wright&Wright
Wright&Wright
  • 309 posts
  • Local Club: Central Mini Owners Club
Posted 11 August 2010 - 09:23 PM
She's lookin' mighty purdy!!
Just one question, what do you with the Kurust after you've applied it and allowed it to do it's magic? Sorry if I sound like a complete moron asking that :thumbsup:
#937 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 11 August 2010 - 10:08 PM
I sand it off again (as it's job is done once it's dry) prior to etch and primer.
I think you can prime straight over the top but I find it usually drys quite rough.
#938 Miniowner123
Miniowner123
  • 987 posts
Posted 11 August 2010 - 10:37 PM
seem to be sorting out the very overlooked places for rust, nice work
#939 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 12 August 2010 - 12:06 AM
I can't take credit for that, it was sonikk4 who suggested it and he was very very right!
#940 Wright&Wright
Wright&Wright
  • 309 posts
Posted 12 August 2010 - 11:56 AM
Thanks! Big help as I've just bought tub of the stuff. I'm looking forward to seeing more of Elliot in the future because you're doing an absolutely spanking job :thumbsup:
Greg
#941 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 12 August 2010 - 05:35 PM
Cheers Greg :D.
More progress today:
I think I've had my moneys worth here!
Got the rest of the bulkhead stripped.
Kurusted the whole thing.
There was a bit of stonechip I'd missed here.
Sorted that out.
Now it was mentioned in another thread the negative affects of blocking up the fresh air vents but that it didn't matter as long as the heaters fresh air feed was maintained. Some of you might remember, I welded my fresh air vents and my heater feed up. After some thought I decided the best thing to do would be leave the fresh air vents welded up but remove the cover from the heaters fresh air feed.
Welded up.
Patch removed. Took me a while as my welds were pretty strong which can only be a good thing.
I don't intend to employ the full system of hoses for the fresh air vent. I'm going to get the pipe which joins to the hole in the inner wing and leave it at that. I won't have to worry about crud getting flung in to the pipe as I'm strongly considering investing in some wheel arch liners anyway.
Thanks for looking, should get the bulkhead and under the wings in primer tomorrow :).
#942 tedmcedd
tedmcedd
  • 2,751 posts
Posted 12 August 2010 - 06:50 PM
Love it! I think ill be doing this amount of rustproofing when i get round to getting the bean back on the road...
you could just put some mesh over the hole in the heater intake, stop stuff getting in....
oh, PS, i recon there is more life left in that wire wheel :D lol
Ed
#943 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 12 August 2010 - 07:17 PM
My worry was water splashes and the like Ed. Plus, I'd like the intake of it facing forward so that it acts as a ram intake.
Basically what's got me to do this is the idea that with no fresh air entering the car the air inside is going to get very moist very fast and thus is going to start the rotting process again on a much larger scale. Plus, having a fresh air feed to the heater means I can have fresh cool air blowing in if I so choose without the need for the rust seeker air vents.
#944 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 13 August 2010 - 07:38 PM
Well, some more progress today! However, my camera died upon turning it on so crappy phone pictures incoming!
Rubbed down all the bulkhead and arches and etch primed bare metal areas.
Primer applied under the arches and to the bulkhead.
I think I want to apply at least one or two more coats of primer before I think about putting any black on there.
#945 jayare
jayare
  • 2,093 posts
Posted 13 August 2010 - 07:44 PM
Elliot's looking much better! You and Sonikk have got me worried about what I'll find around my steering rack mount, although I think it has a nice coat of engine oil all over it! Have to have a look tomorrow while I'm trying to get my floor to fit!
JR
10 user(s) are reading this topic
0 members, 10 guests, 0 anonymous users
