Elliot - The Second Attempt
roundnose
1658 replies to this topic
#916 GraemeC
GraemeC
  • 7,437 posts
Posted 04 August 2010 - 02:46 PM
Not too much different, certainly not enough that I'm going to change them!:
#917 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 04 August 2010 - 04:07 PM
Nah I wouldn't either!
Whoever fitted mine on the factory floor must have been lazy, only one of the two retaining tabs for each pipe was used haha.
#918 GraemeC
GraemeC
  • 7,437 posts
Posted 04 August 2010 - 05:42 PM
Technically it should be - the others are left overs from days of hydrolastic pipes that ran in parallel to the fuel/brake lines.
I used them both 'because I thought it looked better than leaving one flapping!
I could've done a neater job with that waxoil though :lol: Oh well, at least I know there's plenty in there!
Edited by GraemeC, 04 August 2010 - 05:43 PM.
#919 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 04 August 2010 - 07:09 PM
Ahhh I see! You learn something new every day! I'll probably fold both of mine over as well.
Haha, don't worry about the waxoyling! When I do Elliot she's going to look horrific down there but I don't really care, I'd rather it was all protected and ugly than exposed to the elements. Especially since not of it really gets seen anyway!
#920 DaveJH
DaveJH
  • 393 posts
Posted 04 August 2010 - 08:05 PM
Wow, just read through your whole topic, so much done here and after 62 pages, still more to come. Look forward to seeing more progress.
#921 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 04 August 2010 - 08:22 PM
Cheers DaveJH, glad you're enjoying it mate :D.
More progress tomorrow for definite, I want all the welds ground down on the front end and then I can get the engine bay and stuff ready to be painted up nice and black again :).
#922 CLM
CLM
  • 817 posts
Posted 05 August 2010 - 07:37 AM
Cheers DaveJH, glad you're enjoying it mate :).
Wonderfull work, wonderfull watching your skill improve through the thread to where you are at this point, deffinatly makes me want to get my mk1 up from my moms house to work on!
One thought, why not some hidden pins on the front of the bonnet that would point towards the rear and slide into some triangles welded in the corners of the front of the engine compartment? Unlock your latches, lift it up and slide the bonnet forward for the pins to disengage from the mounts? It might be a rather smooth mounting system :D
Chris
1960 Morris 850 Deluxe rustbucket in the USA
#923 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 05 August 2010 - 11:41 AM
That's a pretty neat idea CLM, I like your thinking!
I had a similar thought about making some hooks which would hook on to the slam panel, but they wouldn't have been as elegant as your solution!
We shall have to see what happens :D.
#924 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 05 August 2010 - 09:18 PM
Little bit more work done today, not as much as I'd have liked but I had to take a trip to Mini Tech so this is what I got done in the remaining time.
Finished welding wings.
Other side.
Penetration.
Wire brushed loose paint away and protected with zinc primer.
Tomorrows job consists of grinding, grinding and more grinding. Joy!
#925 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 06 August 2010 - 06:13 PM
Some more done today, not getting as far ahead with this front end as I would have liked!
Welds dressed, still a bit more tidying to do here.
A-panel welds dressed.
Front panel to inner wing welds dressed.
And other side.
Repaired my damper mounting point.
Tomorrow I'll finish the joyous grinding and start working on the bulkhead.
Thanks for looking.
#926 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 06 August 2010 - 06:31 PM
Looks like you're making some good progress there.
Look forward to more updates
Regards
Steve
#927 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 08 August 2010 - 06:06 PM
With that rust around the edges it would have paid you to do this
then this
then
then finally this
There was quite a bit of rust inside the mount so taking it off then treating painting etc was the best option. Its only spot welded on so very easy to take off then refit.
#928 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 08 August 2010 - 07:03 PM
Cheers sonikk4, I might well do that. I'll see how bad everything looks once I've cleaned it all up with the wire wheel.
Was it difficult to get it back in the correct place or did you just use the steering rack U-bolts to align it?
#929 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 09 August 2010 - 10:02 PM
Well I finally had a good day at the garage today! I'll try and keep that trend going!
Time to turn my attention to the bulkhead.
Started removing everything to get the pedal box out of the way.
Done.
I've cut the old fuel and brake lines to get them out of the way but I've kept the offcuts so I know what shape I need to bend my new copper items to. I don't have any copper fuel line yet but I shall acquire some.
Spent some quality time with the grinder and the wire wheel.
This is the worst area as someone spilt brake fluid on it sometime ago so its got some pitting, the metal here is so thick though it's not worth doing anything so I've ground the rust out and will kurust it all before I prime and paint.
Passenger side toe board, I found that the flitch hadn't been dressed round properly and was just instead covered with stone chip, it's been preserved fine but I don't see why someone couldn't have spent 2 mins with a hammer and done it properly :/.
Driver side toe board.
As you can see, still more work to be done! I think I'm going to take sonikk4's advice and drill out the spot welds holding the steering rack braket in place so I can sort out the metal behind it. I'm also going to do this with the engine steady bracket as that's showing similar signs of rust ingress. If a job is worth doing, it's worth doing properly eh?
I'm waiting on some bits and bobs to let me finish off the grinding on the wing seams so I can seam seal them up all nice.
I've also moved my schedule back a week, including this week I have 3 weeks to finish the bodywork. That leaves me 1 week to do the prep work for the paint. Then I'll have to find time in the mornings before I start my days work to lay some paint on. Should be fine as long as she's painted before mid September.
Thanks for looking :).
#930 analogue_radio
analogue_radio
  • 4,897 posts
Posted 10 August 2010 - 06:19 AM
Another effortless update Adam :)
