Went round today for an hour or so to do some tid bits.
Tried to work out where my Aerocatches are going to go so I can suss how large the steel triangles need to be in the corners of the engine bay. However I can't work out what orientation would look best:
Point towards the front.
Point towards the front panel.
Point towards the center line.
Anyway, regardless of the final decision, I wanted to beef up the bonnet in the areas where the catches will bolt on, just for my own piece of mind.
Marked them out, decided against the bracing strips in the end.
Poured some resin out, this is pre-hardener.
Laid up some matting.
That should keep the bonnet rigid after I make the cut outs and it should help prevent the screws pulling through on the front pins. However, I might just buy some button head machine screws and hold them on with nuts and bolts anyway. We shall see.
Thanks for looking, I'll go down and do some more work tomorrow
