#796
Posted 08 April 2010 - 07:47 AM
Keep up the fantastic work
#797
Posted 09 April 2010 - 12:16 AM
Cheers mateBeen keeping an eye on this, very nice work, am about to start on my boot floor, should be fun.
Good luck with your boot floor! It has to be my least favourite bit of a Mini to repair, I never seem to do it as well as I would like.
#798
Posted 11 April 2010 - 12:08 AM
Panels removed again.
Driver inner wing.
Passenger inner wing.
Stripped.
Stripped.
Test of wing to scuttle.
I can't work out the best way to replace the sections of inner wing I removed, which is why I stopped.
Thanks for looking
#799
Posted 14 April 2010 - 04:56 PM
After the good advice I got in the Bodywork section I felt more prepared to tackle the inner wings.
Cut out.
Cleaned up.
Weld through primed.
A-panel I did for the flip front needed to come off.
Done and lip cleaned up and weld through primed.
Got the inner wing pretty close, still needs a bit more tweaking before I'll be 100% happy with it.
Doesn't quite come far enough forward at the top.
Overall look.
This is why safety gear isn't optional. This disc wasn't even cutting anything, I turned the grinder on and BANG. The disc shard hit me in the face (safety mask).
Tucked away in the garage.
Thanks for looking
#800
Posted 14 April 2010 - 05:03 PM
#801
Posted 14 April 2010 - 05:23 PM
Cheers LukePlain sailing as always Adam
I'm gettoing anxious to drive it but I don't want to rush to the finish.
#802
Posted 13 May 2010 - 03:04 PM
#803
Posted 15 May 2010 - 02:20 PM
#804
Posted 31 May 2010 - 10:27 PM
Driver side inner wing welded up.
Driver side wing gap.
Passenger side wing gap.
Driver side scuttle gap.
Passenger side scuttle gap. This one still has some more work to go before I'm happy with it.
Driver side stuff is pretty much all in the right place.
More updates soon
#805
Posted 01 June 2010 - 07:07 PM
#806
Posted 01 June 2010 - 07:45 PM
You can be there pushing, pulling, clamping, grinding, etc. for ages!
#807
Posted 27 June 2010 - 12:55 AM
Progress has been coming slowly but surely, Elliot currently sits in the garage looking like this:
I'm now back at home from Uni and I'm going to need my own car again by September so between now and then, some serious work is going to go in to Elliot.
Keep watching
#808
Posted 28 June 2010 - 06:15 PM
#809
Posted 28 June 2010 - 06:31 PM
#810
Posted 28 June 2010 - 06:54 PM
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
