#751
Posted 23 February 2010 - 12:03 AM
Andy
#752
Posted 19 March 2010 - 11:25 PM
Progress is being made, albeit very quietly!
Much louder progress coming soon, including imagery!
#753
Posted 20 March 2010 - 12:47 PM
Keep going, good bit is in sight.
#754
Posted 21 March 2010 - 03:38 PM
I have a quick question if you dont mind? The boot floor has gone in the corners on my mini and im currently sourcing panels to sort it, i've got the interior boot repair panels and a rear valance, but what are the repair panels called for the little box section that the rear valance attaches to in the corners?? The black bits in the picture below. Where can I get them?? Many thanks
#755
Posted 21 March 2010 - 05:33 PM
Not a problem sirSome good work going on in this thread, keep it up!
They are called valance closing panels. If you search on Mini Spares, they do 3 types. I used the cheapest ones, which I found needed alot of modification to fit properly.
#756
Posted 21 March 2010 - 06:31 PM
Out of the vinegar now.
Adjust bolt removed finally and cleaned up as best I could.
Etched.
Red oxide.
Some awful hammerite spray paint I bought, won't be buying it again.
Etch primed superfins.
Then VW brilliant orange.
More coats of crap rattle can paint.
Drums finished, they aren't perfect, but they aren't going to be seen that much.
Backplates and other bits brush painted with rustoleoum, which does a much better job than hammerite spray.
One side of the remaining radius arm done.
If if they tack off before I go to bed tonight I'll put another coat on some things and paint the other side of that arm. Should be able to reassemble the radius arms on Tuesday
Thanks for looking.
#757
Posted 21 March 2010 - 08:22 PM
Image.
Top man, thank you
#758
Posted 22 March 2010 - 09:26 AM
when is your easter break? if youre around you could drop by when im back??
#759
Posted 22 March 2010 - 08:36 PM
nice work you have there
#760
Posted 22 March 2010 - 09:00 PM
I'm on Easter break now Ed, however between working on Elliot and revision, I'm not really going to have time. Summer though, if you're at home, I'll be over sirlooks top! i really am getting annoyed that i cant work on minis... i keep coming back to projects im watching and get all jealous!
Thankyou sirhmmm super fins
#761
Posted 23 March 2010 - 09:07 PM
Parts of gear selector.
Assembled.
And then there is a part which has me confused:
There is a cut out in the base (on the left, below the middle bolt in this picture), at the moment, it's blocked with grease, but if it weren't, it'd allow direct access inside the casing. Seems daft to me but is this correct?
Thanks for looking
#762
Posted 23 March 2010 - 09:20 PM
keep it up!
#763
Posted 24 March 2010 - 10:06 AM
#764
Posted 24 March 2010 - 10:07 AM
Ah, turns out I do too! You can just about make it out on the photo, you can see the dust sheet through the hole.
Edited by analogue_radio, 24 March 2010 - 10:08 AM.
#765
Posted 24 March 2010 - 12:26 PM
I didn't notice mine had a cut out either until I put it back together and then I wondered if it was even meant to be there. There are very few pictures kicking about of gear selectors so I appreciate your response sir!
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
