Elliot - The Second Attempt
roundnose
1658 replies to this topic
#706 tedmcedd
tedmcedd
  • 2,751 posts
Posted 30 December 2009 - 11:51 PM
top sir! top!
i need to stop being lazy and get working on the mk2... lol!
leave the drums as they are i say!
#707 Mini Basher
Mini Basher
  • 424 posts
  • Local Club: Mini Foresters
Posted 31 December 2009 - 12:54 AM
I'd leave the drums as they are now as well plus you'll get better heat dissipation from unpainted drums, coming along well though
Andy
#708 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 31 December 2009 - 02:08 PM
ive not bothered painting my mini fins they look purdy all destressed aluminum esk
#709 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 28 January 2010 - 09:30 PM
Long time no update! Mostly because nothing has been happening, sadly. However, these last two weeks there has actually been some progress so here is the first update.
Rusty closing panel.
Cardboard template made to record the shape.
Choppy choppy.
From the inside.
Started the repair.
Quater that needs work.
That was it for that day, this was done before I had to go to Uni for a lecture so not bad!
Now here is the todays update.
What I had to work with.
Another piece let in and both seam welded.
Beneath.
Welds ground back roughly.
Beneath.
Bit of filler work.
Zinc primer.
Beneath, again.
Bit of high build.
Looks ok, still needs a bit more work to get it smooth enough for paint but there is plenty of time for that while I work on the welding.
Thanks for looking guys and girls, sorry for the really scattered updates!
#710 sweetser
sweetser
  • 3,995 posts
Posted 29 January 2010 - 03:04 PM
Looking good mate :thumbsup:
#711 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 29 January 2010 - 03:48 PM
Thankyou sir :lol:.
If the weather stays good I'm going to head round and do some more work on her tomorrow.
#712 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 03 February 2010 - 04:54 PM
Well not so much an update as a note for myself on stuff I need to buy and an explanation why.
Anyone who's read the Bingley thread in the Events section will know on my way back from Bingley, the front driver side wheel bearing on my daily drive seized (while doing 70MPH on the M6), which made for a bit of a concerning experience which basically has left me a bit apprehensive about driving Minis. Especially as the wheel bearing was looked at by a garage in December and they deemed it to be fine.
Anyway, as a result of this I've decided that despite the cost, I'm going to do the following on Elliot's mechanical bits:
  • Get radius arms professionally reconditioned
  • New rear wheel bearings, both sides
  • New front wheel bearings, both sides
  • New ball joints, both sides
This along with the stuff I already have to go on Elliot:
  • New callipers
  • New brake shoes
  • New brake pads
  • New copper brake lines
  • New braided brake hoses
  • New rear brake cylinders
  • New brake shoes (and springs)
  • New knuckles (front and back)
  • New bushes all round
I'm hoping will put Elliot's mechanics in such a good state that I won't need to worry about having a repeat of sunday in my car when she's back on the tarmac. It's still a set back, but at least it's a set back to improve things!
I was contemplating replacing the rear subframe as well, but there is a good few years of life left in this one yet, and at £300 a pop, it's best to get the most out of it. I'll be giving the car a thorough once over every few months when it's on the road anyway. I love Minis and I intend to keep driving them :).
Edited by Deathrow, 03 February 2010 - 04:59 PM.
#713 1984mini25
1984mini25
  • 8,784 posts
Posted 03 February 2010 - 10:51 PM
I wouldn’t be surprised if the garage just torqued up the wheel bearing a bit more with the old windy gun to remove any pay. The only problem is that then over loads the bearings, heats them up and you know the rest...
#714 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 03 February 2010 - 11:00 PM
Well he told me that the squeaking from the wheel (that's what I took it in for) was because some crud had got behind some seal or something so he said he'd had it apart, cleaned it and re-greased it. This did solve the squeaking, which then returned shortly before the bearing failed!
Sigh!
Anyway, having none of that again so I'm replacing all Elliots consumables like that, wheel bearings, ball joints, suspension knuckles. Just to be safe and secure.
#715 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 04 February 2010 - 03:56 PM
Managed to get to the garage and make some progress today, not a great deal because my morning was spent going to collect the MPi after it'd had the wheel bearing replaced and then it started to rain about an hour before I was going to finish up.
How I left it last week.
Outer lip tacked in place.
Underside, all sprayed with weld through primer.
Thought I'd make a start cleaning this mess up while I waited for the primer to dry.
I didn't get very far, I did a good job of welding this to everything in the local area haha.
Lipped part of the closing panel repair offered up and clamped in place.
View from the underside.
This is when it started raining unfortunatly. Only one more patch to cut out and tack in place and I can finalise all the welding in that area and start cleaning it all up. I'm working on some mechanical bits and bobs in my Uni room to get that side of the project under way so it'll be completed sooner.
Thanks for looking :D.
#716 tedmcedd
tedmcedd
  • 2,751 posts
Posted 04 February 2010 - 08:21 PM
Top work!
i miss minis so much.... :D may do some work on mine this weekend as im off up home...
#717 BenH
BenH
  • 742 posts
  • Local Club: CV1 Minis
Posted 04 February 2010 - 08:31 PM
your welding is cracking! makes me want to play with my mig in the shed, will keep an eye on this one
#718 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 04 February 2010 - 09:05 PM
Top work!
Do do do! :D
I was dissapointed not to see you about at Bingley Ed. I asked Bec if you'd been for your badge and she said you came and got it and legged it! Haha. Next time I'm going to come equipped for Ed hunting.
Cheers sir! It's not very pretty, but it's strong which is what's important. I will be happy when there is no more welding to do though!.
#719 analogue_radio
analogue_radio
  • 4,897 posts
Posted 04 February 2010 - 09:06 PM
What settings is your welder on? & what thickness wire are you using?
I'm going to attempt my rear end first, so your photos are brilliant reference :D
#720 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 04 February 2010 - 09:16 PM
Welder: Clarke 130EN
Settings: 1,MIN (Lowest)
Wire: 0.8 gasless.
Wire feed: Can be anywhere between 3 and 6.
My wire speed varies alot depending on what and where I am welding. Like you increase your wire feed if you're welding in to a corner like an L shape. I don't go by setting so much, I try a little bit and if it's not feeling right I'll fiddle until it is feeling right.
Brave man! I hate the rear end, it all seems like such an afterthought, it just doesn't go together as easily or nicely as the front stuff does. Valance closing panels are my worst enemy!
Edited by Deathrow, 05 February 2010 - 01:21 AM.
