Elliot - The Second Attempt
roundnose
1658 replies to this topic
#691 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 18 December 2009 - 12:54 AM
Cheers guys :).
I got a little bit more done:
With a great deal of messing I managed to get that seized brake drum screw out.
Beneath.
I stripped that lot off and found that the brake adjust is well and truely seized in place so I've left it soaking in WD40, I'll have another go at it tomorrow, if needs be I'll drill it out and buy a replacement.
This is the other radius arm, that I've already painted.
Fitted brake cylinder.
Braided hose and new copper brake pipe fitted. Ignore the white handbrake cable bracket, it still wants a coat of paint :genius:.
Thanks for looking guys and girls. I'm hoping the weather will be ok tomorrow and I'll head to the garage and do some bodywork.
#692 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 18 December 2009 - 12:56 AM
body work inthe snow u should be so lucky :)
#693 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 18 December 2009 - 01:23 AM
This is Lancaster, we never get snow.
It's both a gift and a curse!
#694 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 18 December 2009 - 04:29 PM
Well I failed miserably by getting up at 1:45pm :). So I sacked off what I needed to do in the morning and went to the garage instead, didn't get long but managed to move forwards a little bit.
Hole in the heal board.
Patch made from nice thick sheet.
Welded in.
Ignore the fact the bottom isn't welded, that's because I need to weld a flap on to there that comes over and welds to the floor, but that needs to be done after the outter sills are on. Then I'll seam weld the floor to the heal board on the inside, the more strength the better.
Thanks for looking guys ;).
#695 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 19 December 2009 - 12:57 AM
Well I've just done some more on the passenger side radius arm:
Adjusters installed, shoes and springs installed.
Superfin installed.
As you probably know by now, I'm a little bit more than just a picture tart so naturally I whacked an exacton on there!
Sexy!
I love the look of the superfin through the spokes. I'm very tempted by a black wheel/orange drum combo now :D.
Clearance at the back, this concerned me until I realised that of course, the drum rotates with the wheel.
I'm tempted to clear the desk now and tear down my gear selector, or maybe have another go at that siezed adjuster in the other radius arm.
Thanks for looking :P.
#696 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 19 December 2009 - 01:33 AM
Well I had a go at the radius arm, still as seized as it was :D.
I'll have to take it to someone to have it heated up, see if I can remove it with a bit of heat. Fingers crossed. Anyway, I started stripping the gear selector down:
Grotty looking!
I know it sits under the car and no one ever sees it but I respect the job it performs and I think it deserves to look good, not like this.
A few minutes later.
The bits they never wanted you to see!
I can't go any further tonight as I need a punch to remove the roll pins that are holding the remaining parts together, once they're out I can clean and paint everything before I put it back together :P.
Thanks for looking :shifty:.
#697 danny2009
danny2009
    Previously 'gerrard'
  • 1,069 posts
Posted 19 December 2009 - 01:52 AM
looking good mate, glad to see you have a trusty hammer to hand :D
#698 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 19 December 2009 - 02:34 PM
Oh the hammer is a good friend! Especially when dealing with brake drums that don't want to come off :P.
#699 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 19 December 2009 - 04:57 PM
Just FYI them roll pins can be a right sod to remove!!
Good work :D
#700 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 19 December 2009 - 05:00 PM
Good work :D
Do I need a bigger hammer?
They need to come out though, I want to get it all nice and clean.
#701 danny2009
danny2009
  • 1,069 posts
Posted 19 December 2009 - 06:05 PM
Good work :angel:
i like how you work :lol
they ususally are seized in or mine was, just soak them in WD40 :)
#702 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 29 December 2009 - 04:50 PM
Been to the garage for a bit today.
How I left the heal board repair last time. After checking, there wasn't enough penetration for me to be happy.
So I ground back the weld and then rewelded the patch with a higher wire feed, good penetration this time :thumbsup:.
Welds ground back.
Etch primed.
Marked out the section that needs to come out of the passenger side rear quater.
Chopped it out to find rust, nom nom.
But I was expecting it, as you can see from below.
Zinc primed the heal board repair.
The next job is either getting the valance closing plates welded on in the right place and get the valance on, or I'm going to sort out these rusty bits in front of the passenger side arch.
Thanks for looking, we'll get there in the end! >_<
#703 analogue_radio
analogue_radio
  • 4,897 posts
Posted 29 December 2009 - 07:41 PM
Followed your picture of the radius arms & brake set up whilst rebuilding mine, copper hoses are quite fun to work with :thumbsup:
What tool are you using to cut rotted parts of metal out? standard angle grinder? I feel like I need to look at something smaller like a dremel.
#704 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 29 December 2009 - 07:58 PM
good work the gear selector is glad i pestered u :thumbsup:
#705 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 29 December 2009 - 08:57 PM
Hehe, the copper pipes are great. And they look so good against nice black arms >_<. They're going to look the business on the car (not that they ever get seen).
Yeah just a standard 115mm angle grinder sir! There are some bits that would be better done with a dremel I guess, like the bit I've just got to, that's going to be a pain, unfortunatly, I broke my dremel clone haha. More than one way to skin a cat though :(.
I haven't touched the gear selector :thumbsup:.
