Elliot - The Second Attempt
roundnose
1658 replies to this topic
#601 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 15 September 2009 - 05:56 PM
Once the welds are cleaned up and the reinforcing plates are welded on and cleaned up, the subframe will be bolted up to the heel board and then the rear will be raised and the hooles drilled using the subframe as a guide :). Then I'll weld in the top floor to wheel arch brackets, job done!
#602 guywithvan
guywithvan
  • 1,081 posts
  • Local Club: MedwayMiniClub
Posted 15 September 2009 - 06:22 PM
:) keep up the good work your home made patches are spot on and set a good example what can be recycled off old panels,i'll be watching closely
guy
#603 tedmcedd
tedmcedd
  • 2,751 posts
Posted 15 September 2009 - 09:04 PM
Ok, now you really are making me feel bad!
Top work sir!
#604 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 15 September 2009 - 10:31 PM
Why thankyou kind sir!
I'm so much happier with the boot floor in comparison with the hack job I did on it last time.
I'm having a very unfun time trying to undo the bolt on the outside of the radius arms, should have done it when they were on the subframe, doh.
#605 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 16 September 2009 - 08:21 AM
pour intrest that a clarke MIG ???
#606 GraemeC
GraemeC
  • 7,437 posts
Posted 16 September 2009 - 08:23 AM
If you need to buy wire locally I'm sure EK's stock it or, failing that, Arc-Rite at Heysham.
In fact - Screwfix do it too!!
Edited by GraemeC, 16 September 2009 - 08:24 AM.
#607 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 16 September 2009 - 08:30 AM
Yes it is.
We have a screw fix?!
I shall check EK's next time I'm down there, I need some more cutting discs anyway. Cheers Graeme.
#608 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 16 September 2009 - 05:10 PM
Here's todays work:
Finished off the welding inside the boot.
Plug welded the arch lips and seam welded where I had to cut in order to form the metal.
Offered bumper up but it wasn't having any of it, did some measuring and corrected my rear panel some.
All plug welded up.
View from inside the boot, you can see the heat penetration in the far corner.
Bumper offered up again, now as a nice even gap inbetween it and the body.
Boot lid offered up as well.
Then the army wanted to know what the hell I was doing. Haha.
That's all for today folks, so tired now.
#609 GraemeC
GraemeC
  • 7,437 posts
Posted 16 September 2009 - 05:36 PM
Screwfix is on White Lund - turn right onto the estate just past Asda, straight down, through the lights, keep going and it is on the left just before you get to the T-junction at the Fiat garage. :thumbsup:
#610 tedmcedd
tedmcedd
  • 2,751 posts
Posted 16 September 2009 - 07:22 PM
Just lovely!
#611 analogue_radio
analogue_radio
  • 4,897 posts
Posted 16 September 2009 - 08:18 PM
Tidy :thumbsup:
#612 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 16 September 2009 - 08:37 PM
Thats not the army its the RAF >_<
Looking good, starting to look like a mini again, keep it up. I wish I had the time to work on mine like you :thumbsup:
James
#613 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 16 September 2009 - 09:00 PM
Haha, my apologies :).
I'm not going to have any time after september, really need to keep on with it :thumbsup:. 2 weeks and the remainder of this week still to work on it. After that, it's back to just weekends. I really need to get it painted before it gets too cold, I don't want to have to leave it in the garage until next year.
Thanks for all the kind comments guys >_<.
Edited by Deathrow, 16 September 2009 - 09:03 PM.
#614 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 16 September 2009 - 10:52 PM
Thats like me, just weekends. It never seems like enough time to get stuck in and make progress.
Are you going to do the spray job yourself?
#615 MR-SKIMMED
MR-SKIMMED
  • 316 posts
  • Local Club: TORBAY MINI CLUB
Posted 16 September 2009 - 11:39 PM
just caught up with this thread from page 24.....
Excellent work, your confidence really shows from the last time i looked, your welding looks spot on.
Keep up the good work :shifty:
