#511
Posted 13 August 2009 - 06:56 PM
#512
Posted 13 August 2009 - 07:03 PM
It's from Arc Angels.exciting! was it from ABS? good fit or no?
It seems to be a pretty good fit yeah, but I won't know for sure until I've sorted the boot floor ready to bond it on.
#513
Posted 13 August 2009 - 07:05 PM
Edited by Deathrow, 13 August 2009 - 07:05 PM.
#514
Posted 13 August 2009 - 07:07 PM
Could Elliot be persuaded to join his stripy-seated friends over on The Designer Register at all...? They don't mind if he isn't original, they'd just like to know he's a Designer that's still out there on the roads.
#515
Posted 13 August 2009 - 07:12 PM
Yeah sure, as long as no one is going to point fingers and shout at me I'm happy to*Sneaks in, sniffs around*
I'll do it once she's finished though so she looks the part at least.
Edited by Deathrow, 13 August 2009 - 07:14 PM.
#516
Posted 13 August 2009 - 09:02 PM
I would personally cut away whats left of the lip that should go over the sill, fit the sill then make the correct plate that fits over the sill then obviously seam weld it to the healboard. If that makes sense, then it'll be the same as mine and original looking.
Thanks for the comment regarding my picture, i've spent ages on the panels i've replaced just havent posted a thread up of my car, i always forget to take pictures and update the thread! lol
#517
Posted 14 August 2009 - 11:00 PM
Could Elliot be persuaded to join his stripy-seated friends over on The Designer Register at all...? They don't mind if he isn't original, they'd just like to know he's a Designer that's still out there on the roads..
No shouting involved. All Designers are welcome regardless of what's been done to them. (Unless they're now candy pink with lilac trim, of course - that's just out of order)
#518
Posted 14 August 2009 - 11:50 PM
#519
Posted 18 August 2009 - 07:10 PM
Here's what I've got done, not masses, but laying down the ground work for good progress:
When I arrived.
Boot floor cut out.
The hole.
One of the many bad repairs done in this area by me when I didn't know any better.
Marked out whats to be replaced.
Passenger side arch rot.
Driver side arch rot, theres another on the top but it's hard to picture from inside the boot.
The lip needs some reworking as I've made a mess of it in the past as well as some rot.
Here.
Bit here.
And finally here.
I've all this to sort before I think about putting the boot floor back in, which will be a pain since the repair section I have is rubbish. There is of course some work still to do on the driver side heel board.
In other news, I've acquired Elliot a new engine, so I've rebuilt the 998 now pretty much as a spare, if I ever have an engine failure I can get the car back on the road in a few hours. The engine I've got for Elliot is a 1275 out of a Metro with only 17k miles.
Thanks for looking
Edited by Deathrow, 19 August 2009 - 05:23 PM.
#520
Posted 19 August 2009 - 11:05 AM
#521
Posted 19 August 2009 - 11:26 AM
She'll be sexy when she's donelol and i thought bertie had a few rough patches hahahahah gonna be MEAN
#522
Posted 19 August 2009 - 12:00 PM
I enjoy reading your updates
#523
Posted 19 August 2009 - 12:10 PM
CheersExcellent work, keep it up
I'm just about to go off to the garage now, as long as the weather stays fine there should be more updates tonight.
#524
Posted 19 August 2009 - 09:50 PM
#525
Posted 20 August 2009 - 10:18 AM
There was this nasty bit on the bottom corner of the rear panel, I'd tack welded a piece of metal to the back and blobbed weld on top of it, ughr.
Grinded the metal off the back and then filed the hole free of thin metal.
Made a repair section.
Welded, looks ugly as sin.
Cleaned up a bit but then my dremel broke so I didn't get chance to finish.
Thanks for looking.
Edited by Deathrow, 20 August 2009 - 10:42 AM.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
