Elliot - The Second Attempt
roundnose
1658 replies to this topic
#436 Burnard
Burnard
  • 3,350 posts
Posted 28 July 2009 - 10:57 PM
This is what I had to do to hold the gearbox while I tightened the two end bolts to 150ft/lbs.
I spy odonalls Nitro fuel... what u running that in?
Your welds are looking good, i think im getting there my self now. got some different wire so i hope its better.
Chris
Edited by Burnard, 28 July 2009 - 10:58 PM.
#437 tedmcedd
tedmcedd
  • 2,751 posts
Posted 29 July 2009 - 12:59 AM
just awesome work dude! well jealous that your welder works! lol!! i should have stolen the one from uni.... hmmmm... lol!
#438 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 29 July 2009 - 08:38 AM
Well spied sir! It's my favourite fuel, burns so clean. I'm using it in this:
It's currently in a box in a thousand pieces though because I've been too busy with Elliot to replace the planet gear it ate in the front differential.
Cheers, it's all down to practice really, but yeah, finding a brand of wire you like does help alot.
Haha tedmcedd, what exactly doesn't work about yours? I'm sure a service of it's parts will get it working again :P.
#439 Burnard
Burnard
  • 3,350 posts
Posted 29 July 2009 - 12:15 PM
Nice car, supprised how standerd it is... means your not treating it properly! :P
#440 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 29 July 2009 - 12:31 PM
Nice car, supprised how standerd it is... means your not treating it properly! :)
It's not standard by a long shot.
You're looking at the original Savage SS (the first Savage to come with a .25) and since then it's had:
Spider diff mod front and back (they only has 2 spider gears back then in the early days)
Servo saver mod (original had one on the servo, which was rubbish!)
1/2" offset RPM wheels
Dynamite Mach .26
Futaba 3PK digital transmitter on 40MHz
High flow filter (Motor Saver?)
Dual disc brake
Header tank mod (solves the half tank lean problem Savages have)
I've got a reverse module too but it's not in atm because I stripped it down to save weight
There's more, but honestly, I've been at it that long I've forgotten more than I can remember. I don't replace the plastic arms and hubs with metal, I like them breaking rather than bending something else. As I say, it needs a planet gear atm. I'll work on building it back up over the winter when Elliot is done :P.
Edited by Deathrow, 29 July 2009 - 12:32 PM.
#441 Burnard
Burnard
  • 3,350 posts
Posted 29 July 2009 - 01:22 PM
Id call that fairly standerd, but a good set up non the less.
Dont get me started on my fleet. :P
Added you on msn, better than taking this off topic
Edited by Burnard, 29 July 2009 - 01:23 PM.
#442 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 29 July 2009 - 02:36 PM
I'm currently having a colour dilemma, I can't seem to make up my mind between:
LP2B - VW Orange
P20B - VW Brilliant Orange
The small box is VW Orange and the laptop is VW Brilliant Orange:
Hmmmm.
#443 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 29 July 2009 - 02:42 PM
VW Orange, more vibrant.
#444 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 29 July 2009 - 03:00 PM
At the moment I'm leaning towards the Brilliant Orange.
The other is nice, but it's a bit in your face and in the light it almost looks a bit pink.
#445 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 29 July 2009 - 07:54 PM
Not alot done today, but progress is progress huh :thumbsup:.
Transfer casing put on and torqued up.
Clutch seal put in along with primary gear and it's c-washer.
Clutch on.
Basically now, the engine needs the bell housing putting on, the head refurbing and putting on and the timing cover and bottom pulley and she's pretty much done, minus the dizzy and carb :).
Thanks for looking :teehee:.
#446 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 30 July 2009 - 05:45 PM
Managed to get some more work done on the bodywork today so here it is:
Todays area of attack.
I modified part of the repair section I didn't use for the other side.
Marked out where to cut.
Cut out.
Repair tacked in place.
Fully welded and partly ground down.
Finished up properly and etch primed.
That repair will need a skim of filler as expected but it should come out looking just fine :-.
GraemeC has just been round and lent me a valve spring compressor so that I can strip the cylinder head down, clean it, check it over and put it back together with new valve stem seals ready to pop back on top of the 998.
After having the front in place properly I've decided that I don't like the tabs I welded on to the a-panels, especially on the passenger side as the welds distorted the panel ever so slightly. Instead of going back on what I've done by trimming the tabs to how they should be, I've decided for the sake of £12 I'll just replace both a-panels again, there are a few tricks I've learnt in order to do them well anyway.
So once the passenger side is done, I'll be moving on to the boot and leaving the a-panels and front end to be one of the last pieces of bodywork before I prep the whole thing for paint.
Thanks for looking :wub:.
#447 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 30 July 2009 - 06:21 PM
Looking good mate, keep it up :- .
#448 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 30 July 2009 - 06:22 PM
looking good like the fabrication work you've done there
#449 tedmcedd
tedmcedd
  • 2,751 posts
Posted 31 July 2009 - 03:13 PM
brilliant orange for sure :(
my welder is being annoying, every setting i try is rubbish! lol, i guess its because i used a gas mig at uni, and mine is gassless... hmmm....
#450 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 31 July 2009 - 04:06 PM
Yeah I think Brilliant Orange is what's happening, the other one is too neon and garish I feel.
What makes you say it's rubbish? Getting alot of spatter? That's just gasless, mine spatters all over the shop (usually in to my hand :(), but it can't be helped really.
