Elliot - The Second Attempt
roundnose
1658 replies to this topic
#331 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 24 June 2009 - 10:49 PM
Cheers guys :).
It's good to have some time to spend on Elliot, working towards somthing again.
I'll keep this updated :D.
Edited by Deathrow, 24 June 2009 - 10:49 PM.
#332 GregH
GregH
    Is Praying To The God Of Wheels Right Now
  • 261 posts
  • Local Club: P&SMOC
Posted 26 June 2009 - 05:40 PM
hi there. i have just scanned over this thread an it looks good. with the gear box you want to check the dog gears on the side of the gear. these teeth were a real mash on mine and i had to replace 1st and second. if your rebuilding it i would suggest replacing the two main roller bearings.
looks great.
greg
#333 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 26 June 2009 - 05:55 PM
Little bit more done:
Started off with an empty, clean gearbox casing.
Cleaning each part as I put it back in the box.
Selector forks and bell crank levers reinstalled.
Can't for the life of me get this bush to shift so I can change the baulk rings.
How I left it.
Need to get that bush off and find a way to press in the retaining pin for the 3rd gear retaining plate then I can change the baulk rings and begin reassembling the gears back in to the box.
Thanks for looking :thumbsup:.
#334 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 26 June 2009 - 07:11 PM
Cheers Greg, only just saw your post as we posted at similar times.
Also, in case anyone has a set, I'm in need of a set of drop gears, as my 998 ones don't fit so I assume the ones I need are 1275 specific.
#335 dezshearer
dezshearer
  • 441 posts
  • Local Club: mini-chat.co.uk
Posted 26 June 2009 - 07:19 PM
brilliantly clean! Love It!
#336 GraemeC
GraemeC
  • 7,437 posts
Posted 27 June 2009 - 07:42 AM
Even with 1275 drops there are different types. Well different size shafts on the idler gears - is this an A series or an A+ box?
A+ casing the idler bearings are about 35mm O/D and 22mm ID
A casing the idler bearings are about 27mm O/D and 19mm ID
#337 GregH
GregH
  • 261 posts
Posted 27 June 2009 - 09:42 AM
that sleeve that the bearing runs on needed tapping down with a punch at a very akward angle on mine. i found that sharp taps worked better than lots of small taps. also i found that it was easier to get off if the outer sleeve of the syncro was removed. but this does mean rebuilding the syncro hub.
the plungers on third and second gear are a pain in the arse but just need patience.
its looking great. wish i could get some straight cuts in my engine but no such luck lol.
greg
#338 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 27 June 2009 - 01:52 PM
It's an A+ box.
Is it possible for me to just get the drop gear that goes on the crank? As it seems thats the only one that is causing issue.
Cheers greg, I'll give that a go on the bushing, I'm not scared of rebuilding the synchro as it already exploded on me once and I managed to find all the bits scattered about my room.
#339 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,851 posts
Posted 27 June 2009 - 02:45 PM
I used to have a grille like that :(. Loved it :). Had the same ring lamps in too but i swapped them for lucas ones and put the ring ones on the bumper. Looking back it looked crap but when i got it i liked the look of it :).
#340 GraemeC
GraemeC
  • 7,437 posts
Posted 29 June 2009 - 08:03 AM
You should be able to replace the primary gear with another A+ one - what's the issue with the one you have now?
#341 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 29 June 2009 - 10:49 AM
It's from my 998, so it doesn't fit over the crank properly.
Or am I being a lemon and it should fit?
Off to do some work on the car today so I'll post an update later, but my word is it hot today!
#342 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 29 June 2009 - 11:52 AM
Hold the Syncrohub in a vice, then smack the Shaft downwards with a hamer, this should cause the Hub and the hat to come off with each other as the shaft moves downwards.
#343 GraemeC
GraemeC
  • 7,437 posts
Posted 29 June 2009 - 01:49 PM
I see - definately different between 998 & 1275 primary gears.
I have a 1275 one spare.
#344 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 29 June 2009 - 06:36 PM
PMed sir!
I do have an update to write up but it'll have to wait until I'm back as I'm heading out for a bit now.
#345 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 29 June 2009 - 08:45 PM
Righty, heres an update:
Started tackling this section more today.
Rusty hole in arch filed out to good metal and a patch section made and welded in.
Finshed welding in the patch I had started on the inner sill.
Seam sealed and painted, this is the current state of the driver side inner sill.
Lower quater panel repair prepared.
Slowly but surely I got it welded in all the way round.
Overall look at the rear quater, still work to do under the window.
I had some rust pitting in my scuttle in the middle, not bad enough to warrant cutting and repairing so I've filled the area after I was sure it was back to bare good metal. Theory being, I can replace my scuttle when I need to because of the flip front :).
This also arrived today, needs a good cleanup and the clock needs a refurb but it'll be fine.
Cheers for looking, I need to read up on metal shrinking now as I've got a bit too much at the bottom of my rear quater and it's causing the panel to pop in and out with pressure.
Comments welcome as always.
