Elliot - The Second Attempt
roundnose
1658 replies to this topic
#211 dezshearer
dezshearer
  • 441 posts
  • Local Club: mini-chat.co.uk
Posted 16 April 2009 - 10:06 PM
My old one was rougly the same (distance) before the old owner had the misfortune of a transfer gear finding its way into the gearbox!
For the price of a new one, it's something that's worth replacing when an engine rebuild is concerned!
by the way, your a panel welding = fantastic! You're really getting the hang of the metal glue!
#212 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 16 April 2009 - 10:18 PM
Sheesh! How did that happen?!
Well the new one is sat there now so it might as well go on during the build, seems stupid not to. I'll attempt to make the old one in to a clock or something haha.
Thanks for the welding comments, I wasn't sure how well I'd managed it so all the comments really help my confidence with it >_<.
#213 dezshearer
dezshearer
  • 441 posts
Posted 16 April 2009 - 10:28 PM
Well he had the 1310 block, with 101bhp from the dyno!
However, the gearbox he had below it was an old type, and basically couldn't handle the power. The transfer game went inwards, into the gearbox, hit off 1st gear and took a huge amount of casing with it!
Also why in my build i've got a second hand newer gearbox, and had it completely rebuilt, with Straight Cuts and a Cross Pin Diff, eliminating the weaknesses of the old box!
Edited by dezshearer, 16 April 2009 - 10:29 PM.
#214 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 16 April 2009 - 10:34 PM
101! Thats impressive!
Bit of a scary story too!
My gearbox is from my '88 so shouldn't be a weakness once it's rebuilt, with any luck anyway. I'll rebuild the diff too if it needs it.
I can understand why yours would need uprating though if you're intending on S/Cing it!
Edited by Deathrow, 16 April 2009 - 10:35 PM.
#215 dezshearer
dezshearer
  • 441 posts
Posted 16 April 2009 - 11:06 PM
Well it might be the sole reason for my student loan reason next year!
Baked beans are pretty cheap!
#216 joe_m
joe_m
  • 1,240 posts
Posted 17 April 2009 - 11:42 AM
just read this through from the start. . . good work!
Its threads like this that make my think my project is easy. Just need to get my welding up to scratch, gues thats 80% of the progres really.
Cheers mate, really enjoyed reading it!!
#217 zebidee
zebidee
  • 444 posts
Posted 17 April 2009 - 11:47 AM
I've become quite jealous at your recent purchases >_< !
#218 tuktuk
tuktuk
  • 1,231 posts
Posted 17 April 2009 - 11:51 AM
come leaps and bounds since i last looked ! good work >_<
#219 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 17 April 2009 - 08:57 PM
Glad you enjoyed it chap :), I'll be heading over for a read of yours shortly, I've not looked though it in a while, wondering how you're getting on :gimme:.
I've become quite jealous at your recent purchases :lol: !
Haha, I tell you whats not jealous of them, my debit card! Hoping it'll make it a nice fun drive though, not over the top unreliable mentalness, just something that will be a good blast on the lanes :gimme:.
come leaps and bounds since i last looked ! good work :P
Thanks mate :). With any luck should be able to show you it at a show later this year (or early next year, haha).
Anyway, on with an update I think! It's a big one today, 26 pictures in all.
My friends Dad had left the drive blocked so I couldn't get the car out but I figured since I was there I'd do something that would need doing later anyway then it's not a wasted day. So I set off organising the wiring and stripping the bulk head.
Wiper motor on its way to being removed.
And out.
Wiring labeled appropriately.
Passenger side of bulk head, what a mess!
Lets face it, where British Leyland are concerned this could mean anything!
Front and rear loom connections labeled ready to be split.
Bullets were corroded, some came undone after some WD40 and tugging and others broke. In the end I cut the remaining ones. I intend to get a weather proof connector to replace the 9 bullet connectors BL used, seems stupid when it could be put in to one waterproof plug.
Bulkhead brushed down, seems I had half a bush on there >_<, still, better than rust!
Every single one of these clips I've come across so far have been rusted solid. I've stopped bothering to try a screw driver on them...
...I'm using these instead. All the clips will be replaced with jubilee clips anyway as my friends Dad can get me a bunch from his work :).
Like magic!
Soaked these in WD40 before I even considered going near them, the result, 3 came off and one sheared, not bad.
The only part of the loom I have failed to identify, I'm not sure its ever been connected to anything. Does anyone have any ideas?
All wiring passed through the bulkhead hole...
...and secured in a big bag so its out of the way.
Brake and clutch master cylinders removed along with the bias valve off the bulkhead. Anyone who's removed a master cylinder before will now understand my unconditional hate for split pins.
Doesn't look good does it :dontgetit:.
Wire brushed up, although the metal is pitted, it is very solid. It will be treated and prepped properly before it gets a nice coat of paint.
I think my wire brush has had it.
Then it was time to come home and get something to eat, but afterwards I still felt like I could get a little bit more done but there was no point heading back to the garage.
#220 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Lugged my engine block outside.
Covered in degreaser.
Degreaser did its work and I scrubbed the block.
Then rinsed the lot off.
Dried with compressed air, all holes blown out and then moved back to the work bench.
First coat of black applied to both sides.
I'll be applying a second coat later tonight and then using a stanley knife to clean the paint off of any mating surfaces, once thats done I might even get as far as installing the crankshaft, pistons and cam tonight. If I do I'll probably update this thread again later.
Thanks for looking guys, I know this one was a bit of a long one, but that might be a good thing, you tell me >_<.
EDIT: Had to split it in two! That is long!
#221 joe_m
joe_m
  • 1,240 posts
Posted 19 April 2009 - 10:39 AM
im getting on slooooooow. i have just started working on her again the last few days so updates should be coming in thick and fast now!
#222 carboy001
carboy001
  • 1,065 posts
Posted 19 April 2009 - 11:06 AM
Oh yes they were an absolute *woman of ill repute* to get out >_< I had to lie down backwards with head wedged against floorpan to see and mess about with a pair of pliers, it hurts with all the blood going to your head ;)
The engine block looks tasty >_< think i'll be going for black block aswell with red cylinder head and silver gearbox and clutch housing :D
Good progress, keep it up..... till you go back to uni anyway :P
Edited by carboy001, 19 April 2009 - 11:08 AM.
#223 analogue_radio
analogue_radio
  • 4,897 posts
Posted 19 April 2009 - 11:08 AM
Really nice updates, missed the last couple of days on this! so you're planning on putting all your wiring inside the cabin ay?
#224 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 19 April 2009 - 05:20 PM
Oh yes they were an absolute *woman of ill repute* to get out :P I had to lie down backwards with head wedged against floorpan to see and mess about with a pair of pliers, it hurts with all the blood going to your head :)
Same, I went dizzy when I stood up :(.
Sorry to confuse, the wiring is only in there temporarily while the bulk head gets work done to it then all the wiring will be sorted, resleeved and reorganized for in the engine bay :).
Well back at Uni now so work will slow but I'll do what I can when I can.
#225 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 21 April 2009 - 07:55 PM
Not really an update but a picture all the same. These arrived yesterday:
Full set of adjustable GAZ lowered dampers.
Sorry about the quality of the picture but I guess most will know what they look like anyway :thumbsup:. I decided these were a worthwhile purchase since the shocks I took off the front were dead as a dodo and the backs can't be any better. They're a bit ahead of schedule but I got them cheaper because of one of the lovely TMF+ group buys :thumbsup:.
Might be able to get some garage time tomorrow with a bit of luck, we shall see.
