#1546
Posted 06 June 2013 - 11:40 PM
#1547
Posted 07 June 2013 - 06:11 PM
Top stuff!
Glad you decided to weld the bonnet, I'd have suggested that too...
Nice to see you back at it!
#1548
Posted 17 June 2013 - 01:06 PM
Anyway, here we are:
Bonnet holes welded up.
Dash rail mounting holes welded up.
And the other side.
Ashtray hole welded up, not perfect but the best I could do with the mangled mess that was there.
Wing stripped bare for some filler work.
I love the finish, I wish I could leave it like that.
Bonnet filled and a quick rattle can covering of paint. You can just see the edge of the filler but it'll smooth out on the final block down.
Some filler on the wing. The large area at the back is where I warped it welding up the aerial mounting hole. The other smaller bits are from dents from being in the garage for such a long time.
A quick rattle can to protect it until I return again (hopefully sooner rather than later).
Thanks for looking
#1549
Posted 21 June 2013 - 09:19 AM
Looking great! Glad there is progress being made!
#1550
Posted 21 June 2013 - 11:52 AM
fantastic build!
#1551
Posted 12 November 2013 - 01:53 PM
any updates?
#1552
Posted 17 November 2013 - 09:24 AM
This has been a fantastic build thread and I'm amazed at the quality of your work. You can really see how spending the extra time to get it right is worth it in the end. This is one of those seminal tmf threads, along with Hugh's poor mini sky and project erm. No doubt there are a few more too that I haven't got to yet.
Please don't be tempted to finish it off quickly, as you won't be happy and have to go back and do it all again (learnt that lesson the hard way).
Thanks for documenting this so thoroughly, it is another valuable resource for all mini owners.
Clovus
#1553
Posted 23 January 2014 - 04:09 PM
#1554
Posted 24 January 2014 - 12:53 PM
Glad to see some progress again
keep going
#1555
Posted 11 February 2014 - 10:04 PM
I know that football shirt any where scott u local
#1556
Posted 05 June 2014 - 09:17 AM
Sorry I've only just seen this reply.
Which shirt do you mean?
Yeah the car is local to Lancaster, I've since moved away from it sadly.
#1557
Posted 13 July 2014 - 02:42 PM
Driver side, prep work complete and high build primer applied.
Now I should try and explain the slow progress. Obviously the big thing is that I've been in full time work for the last two years which rules at working in the week. When it comes to the weekend sometimes there's things going on with family and friends which I want to take part in, sometimes I'm available to work on Elliot and the weather has other ideas.
When I do get to work on her it's slow progress because of all the different types of paint I've applied over the years which all need removing to avoid any reactions with the cellulose paint I'm using. However so far so good, I've followed all the advice that PanelBeaterPeter shared with me and it seems so far so good, even when using an Earlex SprayStation to apply the paint.
I just want you all to know, I've not given up and I will finish Elliot and see her back on the road. The only real question at the moment is whether I'll paint the roof black like the rest of the body as per the original specification or orange to add a bit of my own flare.
Thanks for looking
#1558
Posted 14 July 2014 - 01:51 PM
Nice too see your still going at it! I like the fact you have welded up most the bits your not needing I did that one mine and it makes it looks so much cleaner.
I would suggest one nice touch is to weld up the LHD wipe holes rather then putting those nasty chrome things on .
Great work man!
#1559
Posted 14 July 2014 - 08:02 PM
Interesting to see from the overspray that the spray pattern of the Earlex is obviously much courser, with much bigger droplets. Presumably it still flattens out OK once on the panel?
#1560
Posted 14 July 2014 - 08:24 PM
Graeme I must admit it wasn't as fine as I wanted but I put it down to not thinning the primer enough for the gun. It's high build so I think I could have done with going thinner. It's flattened out reasonably well on the panel, it'll need blocking but it was going to need that anyway. I feel relatively confident I can achieve a good shine with the Earlex.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
