#1531
Posted 11 April 2013 - 08:34 PM
Lesson learnt?? you bet.
#1532
Posted 13 April 2013 - 10:27 AM
#1533
Posted 13 April 2013 - 06:13 PM
#1534
Posted 13 April 2013 - 10:15 PM
http://www.ebay.co.u...=item415e659958
Anyone used a barcoat? Is it worth doing?
used barcoat on my mini and it didnt exactly do its job! could have used it wrong but it bubbled up through the top coat
#1535
Posted 13 April 2013 - 10:21 PM
Sounds like a waste of money and time then.
#1536
Posted 13 April 2013 - 10:29 PM
wouldnt take my word on it, theres a high chance it was my fault!!
#1537
Posted 20 April 2013 - 09:37 PM
Still more to do here.
Tapped down some high spots in the valance.
The other side definitely needed more work.
Sanded down the door step.
Another skim applied here.
And on the door step.
And the other side of the valance.
And the corner of the rear panel.
Got this bit nice and smooth.
Sanded back the top of the rear quarter too.
Paint applied for protection.
Used the DA on the boot lid.
I really love this distressed look.
I'm not sure whether to weld these up or just place a blob of fiberglass on the back and fill over them. I want to smooth the badge off but I wonder if the fiberglass would make it easier to reverse in the future if I change my mind.
Popped the arch on for a little bit of inspiration.
And another, she's going to look good.
More progress tomorrow hopefully.
Thanks for looking
#1538
Posted 20 April 2013 - 09:41 PM
#1539
Posted 22 April 2013 - 12:36 PM
I would go for the weld method Adam rather than fibreglass. you could if you want to re drill the holes in the bonnet.
Thanks Neil, I'll weld 'em up!
#1540
Posted 22 April 2013 - 12:39 PM
#1541
Posted 22 April 2013 - 12:49 PM
Door step smoothed out and top coated for protection.
Finished off the bottom corner of the rear panel.
Finished off the right hand side of the rear valance.
Overall view of the rear. This is ready to be rubbed down, primed and painted now.
While I was waiting for the filler to go off I turned my attention to the top dash rail. I had made a right mess when removing the padded dash rail earlier on and since the dash rail is being left as just metal I wanted to clean it up.
It's hard to see but the metal is all distorted and messy.
Flanges removed as they won't be needed. I dressed the distorted steel as best I could with the limited access underneath, it's quite close to being flat. I ran the DA over it and you can see the low spots where the paint hasn't been removed properly.
Same treatment for the passenger side mounting hole.
And again for the driver side.
I resisted the urge to just cut a piece off the end of my steel rule for the patch panel.
Made a patch piece in mild steel instead. It's still a little bit too big but it was home time.
A little bit more fettling and that piece will be ready to weld in. I still need to make some little circles to fill in the mounting holes at either end. I'll do the welding once I've turned the car around and I can get the nose out of the garage. Once done it should only need a light skim of filler and the dash rail will be nice and smooth for paint.
More next weekend!
Thanks for looking
#1542
Posted 22 April 2013 - 01:07 PM
Looking great Adam!
Thanks Luke
I had wondered where you had gotten to, what's going on with yours now?
#1543
Posted 22 April 2013 - 01:11 PM
#1544
Posted 22 April 2013 - 01:15 PM
Looking great Adam!
Thanks Luke.
Mm last time I was spotted on here was a few months before Christmas I think!
I've made a new thread, see signature.
#1545
Posted 07 May 2013 - 03:01 PM
Just had a scan through
Fantastic job!
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
22 user(s) are reading this topic
0 members, 22 guests, 0 anonymous users
