The two green squared screws are only mounting screws. But the three red squared screws are the electrical connections. The red and black wires at the back are from a multimeter.
Presumably it could work the same as any other rev counter using these three points. I was going to try it with a 1990 carburettor 998cc. Is there a way I can test it without putting a billion amps through it from the engine? Does anyone have the remotest idea how to wire it up? i.e. what each connection on the dial is likely to be for. Is it even possible to use a tachometer from an ECU controlled engine in a carburettor engine?
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/oompf.gif)
