Pin 29 should be the main earth and be black in colour.... is this a single plug ECU or a 2 plug?..... I dont think theirs another black from a single plug ECU...but I stand to be corrected if anyone knows different
As far as I know the following applies
pin 20 BK/PU goes to fuel pump relay coil and from other side of coil in fuel pump relay to pin 11 ECU on a white wire
pins 10 and 15 are the diag connector going to the conector socket on BK/G and W/Y respectivly....
pin 14 is to do with the auto trans inhibitor switch and should be W/LG
pin 21 goes to the purge valve on BK/W
pin 30 is a sensor earth return to the ECU and also gives a base ref to the diag connector
pin 16 is G/BK and is the air intake sensor
pin 33 is the CTS and is P/G
pin 13 is accel pedal switch where fitted and is w/GR
pins 8 and 9 Y/G and Y/PU are throttle pos sensor
pins 3,2,22,27 are stepper motor colours are O/GR, P/BL, O/G, O/BL
pins 31 and 32 are crank sensor BL/PU, W/BL
pin 11 ,BK/W then turns to W at the relay coil in the loom, is other side of fuel pump relay see pin 20 above
pin 25 is W/BK and is for the tacho and coil connection
pin 29 is earth pin and is BK
pin 5 G/BL is to the coolant gauge
This is just as per Haynes and may differ dependant on model.... if anyone has a model specific version Id appriciate a copy.
BL=Blue
BK=Black
BR=Brown
G=Green
GR=Slate
LG=Light Green
O=Orange
P=Pink
PU=Purple
R=Red
W=White
Y=yellow
Hope this helps a bit...
Rob
Edited by DaveRob, 26 June 2008 - 04:32 PM.
