The Italian Job 1969 Bloopers
6 replies to this topic
#1 Danny3320
Danny3320
  • 329 posts
  • Local Club: not a member yet
Posted 13 June 2008 - 07:07 PM
hi was on a italian job search and come across this site http://www.moviemist...m/film661/page1 about films bloopers its really good
Here is the italian job one:
1. Continuity: When the 3 Minis are pushed off the coach, if you look carefully there is view shown briefly of the cars interior, which has red door pillars. When the shot reverts to the external view the cars colour is white.
2. Revealing: In the scene where the 3 Mini Coopers drive on to the coach, the first Mini doesn't have fitted headlights. It also has a brand new rear wheel fitted that is clean and the rest are dirty.
3. Continuity: Right at the beginning, the red car goes into the tunnel and is blown up, yet when it is taken out not one part of the bodywork is charred, it is still a shiny red.
4. Continuity: After the gang is pulled off the bank job, they race away in the three Minis - as they go through a tunnel at one point they roll up and down the sides of the tunnel. The mistake is that each car supposedly has two occupants, but on one shot of the cars in the tunnel, one car has only a single occupant - visible because the car following has his headlights on illuminating the car in front.
5. Other: In the scene where the Mafia are having a dinner party, the film cuts to Charlie Croker throwing his bicycle into the substation to cause a powercut. After the big explosion, the camera switches back to the dinner party and then all the lights go out. But before the lights go out, if you look at the end of the dinner table, there is a doorway, and you can see smoke coming from the candles which have already been lit before the lights go out. Within seconds of the power cut, these candles are brought in from doorway and another set comes in from the left handside. A little premature.
6. Continuity: During the getaway the three minis jump over a ramp chased by the police motorcyclist who then crashes through a wall. When the motorcycle first touches the ground after landing off the ramp it has a clear path ahead without the wall in sight, so the wall seems to appear in front of it in a split second.
7. Continuity: In the scene where the Car transporter is trying to break into the building where they are transferring the gold from the security vehicle, a car drops from the transporter and lands on a police car, the blue cover from the police light comes off completely in the first shot, but a second later you see the face of the policeman with the light in the foreground which now has a jagged broken base left on the car.
8. Visible crew/equipment: As the armoured truck is midway from the airport to the Fiat plant, the film crew is seen in the mirrored finish of the stripe running down the length of truck.
9. Continuity: In the scene where the Minis are going through the tunnel, the police car behind them has a set of lights which are the same as the Minis, which it did not have before.
10. Continuity: Each of the Mini Coopers were fitted with three spot lamps on the front grille/bonnet in a triangle formation. In part of the chase sequence through the sewer, two of the Minis have sprouted three more lights - one under each headlamp and one in the centre of the grille under the three original spot lights.
11. Continuity: The Minis at the end are pushed out of the bus with no rear windows, the Aston pushed over the cliff becomes a Lancia at the last moment, and the Lamborgini pushed over the cliff is so toy-like - it doesn't even have an engine... [Regarding the Lancia, the comment is correct. However, it was a deliberate substitution. The Aston went over the cliff and spontaneously burst into flame almost immediately. The director felt that it looked too fake and the Lancia was substituted to make the stunt longer and more realistic.]
12. Continuity: When the crooks hijack the bullion van, one of the crooks starts covering the van's windscreen with blue paint. He manages to get two small squirts of paint on the windscreen. However, when the camera cuts to Charlie connecting a cable to the van, at the top of the shot, you can see the whole of the windscreen is covered. Then the camera cuts back and he is still painting.
13. Continuity: When we see the computer tape on the tape drive just before it gets to the altered data and messes up the traffic light sequence, the tape is visibly twisted. In the next shot a few seconds later, it is straight again.
14. Plot hole: How did those people in the England bus get out of the traffic so quickly? The ones in the minis had to go through various places - places the police cars had trouble going - to escape quickly, so how did they escape at the same speed in a bus?
15. Revealing: After stealing the Bullion the gang make off through a shopping mall. As the scene changes to show the Minis descending a staircase it can be seen that the door of the front Mini is wide open and the passenger is getting in as the car moves off. It shows that the car was stationary before the start of the shot and not actually descending the stair.
16. Revealing: When the police car crashes through the grating that was dropped down in front of it at the end of the tunnel, the occupants are dummies - they just bounce about in the same upright position whilst the car drives into the river.
17. Visible crew/equipment: In the scene where the three Mini Coopers come out of the sewer and drive towards the coach, you can see 2 people in the coach. "Big William" and Mr. Toms who really drove the coach.
18. Revealing: Towards the end of the movie throughout the Mini chase scene through the building, down the stairs and skidding around corners etc, you can see tyre markings from previous takes.
19. Factual error: When the cars are in the garage being prepared for Italy, Freddie tells Charlie that the red Mini Cooper is having its differential worked on. The mechanic has jacked up the rear off the car and is working on the back axle, but Mini Coopers are front wheel drive. The differential is on the front axle on these cars and working on it would mean removing the whole engine/gearbox unit.
20. Revealing: When the mafia bulldozer is destroying the three cars on the mountain pass, the red jaguar E type has obviously been replaced with a wreck as it has accident damage on it that wasn't there in previous scenes, and away from where the bulldozer hits it.
21. Other: When the film about planning the job is being shown to Mr. Bridger in the prison: at the end of the film the mafia man walks right up to the camera to watch the English guy walk off. This seems a bit odd, him being able to walk right up to the camera and the camera operator still filming. Wouldn't he have wanted to keep the fact that he was watching them all the time a secret and not give the game away that the mafia were on to them?
22. Continuity: When the three minis are trying to drive up the ramps onto the coach the shot from outside the cars shows them to be on a two lane road while in the shots from inside the cars they are on a three lane road.
23. Continuity: When the Minis are practicing jumping, one of them goes tumbling onto its roof, but the other crashes into another car, denting its wing. Just before the impact, you can see that there is already a dent there where it has obviously already done the same stunt.
24. Continuity: When one of the Minis tries to mount the ramp into the coach it has a bit of silver trim behind the front wheel hanging loose. A few seconds later when it tries again the trim is back in place.
25. Plot hole: Why on earth do they drive the Minis up the ramps into the bus while it is moving? They are on a long, straight, relatively quiet stretch of road, but there are cars and buildings about. That ramp is going to make a noise like the sky coming down (we see sparks as it scrapes on the road) and they put on a display anyone would be, frankly, amazed to see. Don't they think one single person would call the police? Don't they think that reports of three brightly coloured Minis will be connected with the recent robbery? They cannot possibly think they have to load the Minis on the run in order to elude the police; they have lost the police cars and are no longer being pursued. Why not just park the bus on the hard shoulder and drive the Minis sedately up that ramp? An unusual sight, maybe, but nowhere near as clumsy, obvious and attention-getting as the way they do it. They are asking to be pulled over and arrested.
26. Continuity: When the three Minis are driven up onto the roof of the Dome Stadium, the first car (the red one) turns right at the top and the last (blue one) turns left. When they drive back down the red and blue Minis have switched ends.
27. Continuity: In the film, when Charlie just comes out of prison, his fringe suddenly moves to a different position.
found some cool pics too:
Posted Image Posted Image
Posted Image Posted Image Posted Image
Danny
#2 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 13 June 2008 - 10:00 PM
I think someone has to much time on their hands lol
#3 Danny3320
Danny3320
  • 329 posts
Posted 14 June 2008 - 10:09 AM
i wonder how many times the person watched this to find them all
i bet he got square eyes ;)
Danny
#4 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 14 June 2008 - 05:29 PM
Still a great film anyway.
#5 Danny3320
Danny3320
  • 329 posts
Posted 15 June 2008 - 08:49 PM
did u know their make a new italian job its called The Brazilian Job same people as the remake
http://uk.imdb.com/title/tt0427396/ <<<< the link to the website
Overview
Director:F. Gary Gray
Writer:David Twohy (screenplay)
Genre:Action | Adventure | Crime | Thriller more
Plot:Charlie Croker and his fellow crew of expert thieves head to Rio de Janeiro to pull off another
heist in this follow up to The Italian Job (2003). | add synopsis
Production Notes/Status:
Status:Announced
Comments:Scripting
Status Updated:18 March 2008
#6 matt615
matt615
  • 923 posts
Posted 05 July 2008 - 09:54 PM
Y
Edited by matt615, 05 July 2008 - 09:57 PM.
#7 blacktulip
blacktulip
  • 6,224 posts
Posted 06 July 2008 - 09:34 AM
have you noticed to negative remarks to your post as you have just mocked the film we all worship? :D lol good find by the way :lol:
