Headlamp Stone Guards
11 replies to this topic
#1 kjbenja
kjbenja
  • 252 posts
  • Local Club: LSMOC
Posted 11 June 2008 - 03:33 PM
I have a set of stone guards for my mini with 2 lots of clips.
I have spent the last hour trying to fit them with no luck :)
I googled it and found a how to fit but I still can't figure it out.
Does someone have a step by step guide for dummies please.
I am starting to get stressed :D
#2 mike.
mike.
  • 6,176 posts
Posted 11 June 2008 - 03:42 PM
Have you removed the outer headlamp ring? They fit under that.
#3 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 11 June 2008 - 03:58 PM
yeh kjbenja said remove the ring around the headlamps little screw from the bottom
#4 kjbenja
kjbenja
  • 252 posts
  • Local Club: LSMOC
Posted 11 June 2008 - 05:06 PM
What do you mean? Screw in where?
#5 Guest_iansmini_*
Guest_iansmini_*
  • Guests
Posted 11 June 2008 - 05:23 PM
I think he means the outer headlamp ring there is a srew right at the bottom.
#6 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 11 June 2008 - 05:47 PM
The chrome/stainless ring that goes round the bulb needs to come off, there's a big screw at the bottom of the ring that that needs to undo,.. then unclip the ring. fit your stoneguard,.. put the ring back on, do the screw up.
that's how mine were meant to be fitted anyway.
#7 captain kirk
captain kirk
  • 857 posts
Posted 11 June 2008 - 07:01 PM
have a look at this
http://www.ocoop.com...stoneguards.htm
#8 kjbenja
kjbenja
  • 252 posts
  • Local Club: LSMOC
Posted 12 June 2008 - 12:19 AM
have a look at this
I tried using the pics above but the clips just fall out when you try and put the ring back on.
#9 kjbenja
kjbenja
  • 252 posts
  • Local Club: LSMOC
Posted 12 June 2008 - 12:20 AM
Mine doesn't seem to fit like that.
#10 BMC Paul
BMC Paul
  • 314 posts
Posted 12 June 2008 - 01:27 AM
These can be a absolute pain to fit! Any pics off the clips etc and shopuld be able to give you some advice, ive fitted a few sets of these with different style clips, by the way the headlamps are a pain to clean when fitted and once they start to rust there a pain and hard to keep clean and polish etc but do look cool, i had 5 on my italain job, 3 on the spot bar and two on the headlights until recently which i removed due to them starting to rust and a pain to change the side light bulbs, had to be striped down everytime i had to replace the bulbs or wanted to clean the headlights properly, im NOT trying to put you off just give you my advice and as belive me ive lived with them! :D
#11 captain kirk
captain kirk
  • 857 posts
Posted 12 June 2008 - 05:32 AM
i couldnt get on with the clips either,so i held mine on with 2 cable ties nice and neat and strong. :D
#12 Sagey
Sagey
  • 487 posts
  • Local Club: The mini forum
Posted 12 June 2008 - 03:34 PM
my friend fitted his at the riv run, went on the cruize and all was good, but went down the local shop and ne fell off! strange.
do look very good when fitted but very fiddley
