Mpi Cooling Fan Fuse
Posted 09 June 2008 - 08:21 PM
Posted 10 June 2008 - 08:32 PM
Posted 11 June 2008 - 12:01 AM
make sure you get one that blows, rather than sucks
Posted 16 June 2008 - 02:30 PM
How did you find that the fan had seized?
Just about to go out and check the fuses on mine, cant believe i didnt check somethign so simple by now. am frequently having trouble with fan not kicking at high temp. mostly in the queues to get into mini shows which can be a bit embarrassing :s
Posted 17 June 2008 - 12:46 PM
wish id checked that originally. whoops
okay, so how can i find out if it's the motor that's seized?
**EDIT** Fixed!
well, mostly. replaced thermostat and temperature sensor. fan finally comes on with engine now, shows no sign of turning off atm, but to be honest i dont care right now, id rather have it on all the time than off al the time
Edited by maieth, 17 June 2008 - 04:11 PM.
Posted 17 June 2008 - 06:20 PM
Posted 08 July 2008 - 01:10 PM
Thought I'd tag along on this thread as I've also been having issues with the fan not kicking in - causing steam to riiiiiise from the engine bay.
I noticed that the B9 fuse has been blowing a lot recently so have stocked up on these while we try to get the cooling sorted.
My dad has today installed a brand new fan, but as yet it is still not turning on.
I'm pretty sure we've already replaced the relay and expansion tank cap, checked all the wiring, and a whole host of other things, but nothing seems to fix the problem.
Am I looking at a new ECU or is there something that I've overlooked?
cheers all.
Oh, by-the-way, the car is a 98 Cooper MPI.
Posted 09 July 2008 - 12:13 PM
I am not sure if mine comes on or not.
Ming
Posted 09 July 2008 - 03:10 PM
Posted 09 July 2008 - 03:12 PM
Does this problem exist with the SPI ???
Ming
You can test the auxiliary cooling fan on an SPi Mini and Cooper by removing the 2 spade terminals from the lower front of the radiator, connecting them together with a paper clip and then turning on the ignition.
The auxiliary cooling fan should then spin.
If it doesn't then check the in-line fuses on the bulkhead behind the air filter box: -
In-Line Fuses situated behind air-filter on the bulkhead: -
15amp - Purple/Orange Wire
Hazard Warning & Interior Lamps
15amp - Brown/Orange Wire
Dim-Dip Lighting
10amp - Blue/Orange Wire
Rear Fog Guard Lamps
15amp - Blue/Red Wire
Auxiliary Cooling Fan (where fitted)
Edited by taffy1967, 09 July 2008 - 03:12 PM.
