Eaton M45 Used To Blow Through A Webber Ideas Pls
55 replies to this topic
#16 mini23
mini23
  • 47 posts
Posted 07 June 2008 - 11:44 AM
Jonspeed kit is suckthrough!
#17 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 07 June 2008 - 01:39 PM
and because its a suck through that is why they get away with it. it is not the nicest way to treat the charger when the throttle closes on the suck through the charger sucks against the butterfly of the carb creating a vacume which make the charger work hard which creates more heat. but you get away with it where as when blow through it forces air against the carb and can push past.
Edited by In-a-mini, 07 June 2008 - 01:40 PM.
#18 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 07 June 2008 - 03:57 PM
hae seen 2 or 3 ars ruuning the supercharger up front then throught a turbo carb like in the pic
i have a webber throttle body with injectors i was going to do this with but going down a differant route now
#19 mini.cooper998
mini.cooper998
  • 685 posts
  • Local Club: looking
Posted 07 June 2008 - 03:59 PM
what about the shorock and opcom chargers they are blow through and neither have a blow off (that i can tell)
also the suckthrough must realy hurt the butterfly spindle on the carband if thats the case could i put a second throttle cable on and a throttle body at the intake to stop the air
also can nobody recomend any of the old cars that may have a supercharger dump valva
#20 In-a-mini
In-a-mini
  • 831 posts
Posted 07 June 2008 - 04:23 PM
hey stig thats cool i can see that he is using the valve from the bini too but dumping the air (just by the servo).
mini.cooper998 most of the cars i know of that were supercharged running carbs were mostly suck through some superchargers have a built in wastgate/bypass so less working out. If your trying to find a different setup than the bypass its probably best you build it and try to get it working
#21 mini23
mini23
  • 47 posts
Posted 07 June 2008 - 04:41 PM
Probably does put a big strain on the butterflies but i've run mine for 2 years trouble free
#22 In-a-mini
In-a-mini
  • 831 posts
Posted 07 June 2008 - 04:55 PM
hiya mini23 great looking car is that the kit i saw on ebay?
#23 mini23
mini23
  • 47 posts
Posted 07 June 2008 - 05:18 PM
The very one.
Fitted with nos in the picture
Quite a bit of interest on ebay, hopefully it will go for good money
#24 mini.cooper998
mini.cooper998
  • 685 posts
Posted 07 June 2008 - 05:52 PM
Stig.
cheers for that looks exactly what i was planning, supprised you got the alternator on underneath it but makes life so much easier. When i get my hands on a BINI S at the scrap yard where do i find the dump valve on the BINI engine and do i need any other parts of the BINI S while im at it
cheers for all your help here. looks like i may give this a go
#25 In-a-mini
In-a-mini
  • 831 posts
Posted 07 June 2008 - 05:58 PM
the valve is bolted to the manifold after the intercooler ond has a pipe down to the inlet mannifold before the supercharger. Apparently these go wrong alot so make sure you dont get a duff one it will cause you grief
red arrow shows where they have three bolts The pic is from the front of the engine
Edited by In-a-mini, 07 June 2008 - 06:04 PM.
#26 mini.cooper998
mini.cooper998
  • 685 posts
Posted 07 June 2008 - 06:09 PM
also would a maestro / montego turbo car work on a 1380 supercharged mini such as this
turbo carb
also whats the thing on the side connected to the throttle cable
thanks all
#27 mini.cooper998
mini.cooper998
  • 685 posts
Posted 07 June 2008 - 06:14 PM
cheers in a mini should i feed the output rom this valve back into the inlet or does it just blow of into the engine bay.
does it sound like a turbo dump valve as well hope so because they sound cool (but not as cool as the wirr from the supercharger)
#28 In-a-mini
In-a-mini
  • 831 posts
Posted 07 June 2008 - 06:17 PM
yes the carb is vertually the same as a metro turbo one the unit on the side is the choke it was water heated from what i remember it can be removed and the bits from a normal hif44 fitted but might be worth a check. i personally would run it back to the inlet if you have the oom for the piping im not sure what it will sound like to be left to blow out.
Edited by In-a-mini, 07 June 2008 - 06:20 PM.
#29 mini.cooper998
mini.cooper998
  • 685 posts
Posted 07 June 2008 - 07:11 PM
cheers in a mini i will start collecting the bits over the next few weeks then start to weigh up the install once the shell is finished
should i intercool before or after the supercharger for best effect
shopping list for the next few weeks and please add if ive missed
Eaton charger
pulleys
belts
metro turbo carb
metro turbo plenum chamber
rising rate fuel pressure reg (how does it change its rate is it linked to the vaccum pipe)
BINI blow valve
Facet fuel pump
return pipe to tank
Intercooler
Pipework from filter to charger
pipework from charger to intercooler
pipework from intercooler to plenum chamber
uprated water pump and radiator
am i missing anything
#30 In-a-mini
In-a-mini
  • 831 posts
Posted 07 June 2008 - 08:04 PM
the regulator has a pipe from it to the plenum it senses boost and raises the fuel pressure by that amount keeping the fuel pressure 4-5 psi above boost level. The fuel pump should be a roller vein type same as the turbo its not so much the pressure it pumps at but more the amount of fuel it can flow. the intercooler goes after the charger to cool the heat the charger puts into the charge.
Edited by In-a-mini, 07 June 2008 - 08:10 PM.
