Elec Ignition Kit For £6.75+vat Found.
#106
Posted 16 February 2009 - 01:56 PM
#107
Posted 16 February 2009 - 02:14 PM
#108
Posted 16 February 2009 - 02:17 PM
#109
#110
Posted 16 February 2009 - 02:22 PM
fitted mine last night and ran like sh#t missfired like hell to i think it may have put the timing out of place managed to get it a bit better but in need of a timing light!! easy to install though
Did you undo the dizzy clamp? shouldn't need to to fit this kit.
#111
Posted 16 February 2009 - 11:11 PM
Just ordered mine now, I'll have to head home sometime now to fit it!
#112
Posted 16 February 2009 - 11:48 PM
#113
Posted 16 February 2009 - 11:50 PM
combe, when my lumination packed up, making it miss under load, dropped one of these in and away we went
Edited by crocks, 16 February 2009 - 11:54 PM.
#114
Posted 16 February 2009 - 11:51 PM
Tried to fit my second one around 2 weeks ago, wired in excactly as instructed, red too coil + and black to standard dizzy earth. Wouldnt start, just cant be arsed with it now, so points went straight back on.
Do you mean you earthed it on the dizzy?
The red goes to + terminal on the coil
The black goes to the - terminal on the coil
Also check the rotor arm is pushed fully home, mine was a very tight fit.
Edit, hello crocks!!
We posted at the same time!!!
Edited by shiftyseamus, 16 February 2009 - 11:54 PM.
#115
Posted 16 February 2009 - 11:52 PM
got to be ign live not coil live (thats how mine is wired up hope it helps)
#116
Posted 17 February 2009 - 12:19 AM
Ohh, thats not what the little instructions said it said, red wire on coil + and black wire to the standard dizzy earth, as in the standard wire coming out of the dizy body.
#117
Posted 11 April 2009 - 10:55 PM
mm69 i know it says to fit red to +ve terminal of coil but a any ignition switched 12v feed is sutiable, this thing with the +ve coil terminal is i dont think its always had a pd of 12v.
thanks for the pics whoever uploaded them.
sam
#118
Posted 11 April 2009 - 10:58 PM
It seemed to give the occasional misfire above 4k, and my rev counter seemed to go rather crazy at times.
I've now wired in a 12v feed directly to the module, and it runs a lot better, and seems to start even quicker!
#119
Posted 12 April 2009 - 12:04 AM
#120
Posted 12 April 2009 - 10:49 AM
It says they are out of stock at the bottom but it says not available until further notice at the top :S.
Would rather pay £16 than £70 odd for a lumenition lol.
