Elec Ignition Kit For £6.75+vat Found.
#91
Posted 23 August 2008 - 09:19 AM
I do have a spare in the back though!!
Engine runs nice, would still recommend it
#92
Posted 05 September 2008 - 07:00 PM
First the kit
First the rotor arm, this is a non standard item but just replaces a standard item
The blue bit is the actual electronics and is held in place using the existing screws on the dizzy backplate
Right now the one down side, depending what type of points you have fitted you may have to modify the backplate
The picture above shows the setup for a sliding points type dizzy, the bit marked red is a peg which the standard points locate against.To fit the system you need to remove this peg.
On non sliding points dizzys the system should just screw straight on, although I can't confirm this.
The bits marked blue above are the standard fixing screw (big) for the points and the screw for the back plate earth cable, these are the two screws used to mount the electronic module
System fitted although that picture was taken before I tidied the internal wiring and pulled the black grommet through the dizzy body
The black wire just connects to the original dizzy spade connection (negative)
The red wire connects to the positive terminal on the coil.
We have fitted it to a 1989 ballasted coil system, the system claims it works with ballasted and non ballasted.
We removed the dizzy for ease of access, but total time from removing, fitting electronic ignition to refitting and firing I would say was 1/2 hr.
After fitting we checked timing and took for a run, working a treat.
Total price less than £15 inc postage
http://www.mm-4x4.co...nsor-2721-p.asp
Edited by lrostoke, 12 September 2008 - 11:01 AM.
#93
Posted 30 October 2008 - 11:59 PM
#94
Posted 31 October 2008 - 12:07 AM
#95
Posted 31 October 2008 - 01:08 AM
#96
Posted 15 December 2008 - 03:47 PM
There's a local motor shop near me owned by some old men - they've really helped me out with when my roberta breaks down. I just bought them one of these electronic kits as an xmas present. They're putting it in their MG.
#97
Posted 15 December 2008 - 05:29 PM
#98
Posted 22 December 2008 - 06:00 PM
#99
Posted 23 December 2008 - 01:23 PM
Also gonna get a new set of ngx spark plugs and a new coil could any one tell me what gap should i do my spark plugs thanks.
#100
Posted 04 January 2009 - 03:27 PM
Is I wanted to put it into a 59D dizzy, 'cause I only run A+ engines, and didn't want to cut the only 59D base plate I had, I fitted the 45D plate instead of the 59D.
Works fine and you can leave the whole contakt-set as replacement in the glove box
It's still a plug & play job (to be honest more than with having to modifie the 59D's plate)
It's just too bloody cold to change the dizzy ATM...
Cheers,
Jan
PS: Postage for 4 modules to Germany was 5 pound at M-M4x4!
Edited by Asphalt, 04 January 2009 - 03:28 PM.
#101
Posted 04 January 2009 - 03:48 PM
#102
Posted 12 January 2009 - 08:26 PM
whats it like in the wet compared to points?
so i could just buy a 45D plate, fit it and swap it over?
cheers
adam
#103
Posted 04 February 2009 - 11:35 PM
#104
Posted 04 February 2009 - 11:43 PM
Took 10 minutes to fit the kit and another fifteen to check timing/fuelling and it's been perfect since.
Idle is also a lot smoother.
I did change plugs/leads/oil/filters at same time, which may have played a part. I do think they are more than worth their price though.
#105
Posted 04 February 2009 - 11:48 PM
Had mine fitted about a month know and its made a hell of a difference to the running of my mini well worth the moneyJust orderd one of these as they sound great and my points and condensor needs changing anyway.
