i've an important question. there are two main types of tacho, one works with the old points system the other works with electronic set ups. so which type would run on this set up. oh and i've just bought a kit,ordered it tuesday got it wednesday!
You're talking about the RVC or RVI tacho's which intercept the signal to the coil from the dizzy on the -ve feed ( basically it passes through the tacho on a loop rather than just a feed wire )
My thinking is, because this is still using a standard coil and not an electronic coil, and the only item which has changed is from a mechanical point to a sensed electronic point, I get the feeling that they will still work..
I'll see if I still have an old RVI/C around and connect it up and find out...
It certainly works with the std 3 clock tacho.. ( which is whats inside my old tacho outer )
Edited by GuessWorks.co.uk, 13 June 2008 - 09:57 AM.
