Elec Ignition Kit For £6.75+vat Found.
#166
Posted 24 May 2010 - 07:58 PM
Also check the carbon brush on cap hasn't fallen out whilst you've been fitting the kit!!!
#167
Posted 24 May 2010 - 08:11 PM
I'd wire it up directly to the coil, thats how I usually wire em up.
Im still stuggling shifty eveything i do on the bloody mini take 10 times as long as it should. This kit should have been fitted in 10 mins everyone else fits it no probs but i try to fit ohhh no doesnt want to work.
I know the kit isnt faulty cause I have a second here and cant get that one to work either.
Tried connecting it direct to coil still no joy carbon brush in cap is still there. Really fed up in general im gonna take a sledge hammer to her in a minute she how she likes that!
#168
Posted 24 May 2010 - 08:13 PM
+12v coming in when the ignition is switched on to the + side of the coil?
#169
Posted 24 May 2010 - 08:18 PM
Right then, lets start from the beginning, is the coil wired up the correct way?
Yep coil is fine and correct. Also the whole setup worked fine with my points? Just in case should risk trying the red wire on the other side of the coil or am I gpnna fry the module?
Edited by Sleepy Stu, 24 May 2010 - 08:18 PM.
#170
Posted 24 May 2010 - 08:20 PM
Stuff like can produce the mysterious blue smoke of death!!!
Hmm.....
The only other thing I can think of is that the trigger(under the rotor arm) isn't being seen by the eye. Can this be moved closer?
#171
Posted 24 May 2010 - 08:31 PM
I wouldn't!!
Hmm.....
Hmm good thinking shifty ive just been down to check but the thing isnt like a normal rotor arm its just a magnetic ring that sit around the top of the shaft (behave you lot family forum)
it seems to perfectly inline with the little red module. Hand on how does all this work? There is now no physical connection to each of the four contacts in the cap as. ok maybe im being a tool but you see the little metal spade thing in the pitcure i hadnt found out where that goes yet?
#172
Posted 24 May 2010 - 08:37 PM
I'm at a bit of a loss?
#173
Posted 24 May 2010 - 08:38 PM
There's 2 ways of wiring this system
See diagram
Also I'm not sure if its still needed but I refitted it on ours, have you refitted the little earth lead from backplate to dizzy body
Edited by lrostoke, 24 May 2010 - 08:40 PM.
#174
Posted 24 May 2010 - 08:39 PM
Lrostoke beat me to it!!
I was just thinking about ballast systems.
I don't think this will work with a ballast ignition, you'll have to convert to a normal 12v system, easy enough, just need a standard coil and a feed straight from the fuse box.
#175
Posted 24 May 2010 - 08:42 PM
#176
Posted 24 May 2010 - 08:44 PM
#177
Posted 24 May 2010 - 08:46 PM
#178
Posted 24 May 2010 - 08:51 PM
If they are getting a spark then its a timing issue not the fitting of the unit
#179
Posted 24 May 2010 - 08:58 PM
Have you checked if the plugs are getting a spark ??
Cheers dude unfortunaly I dont have a volunter at the mo to turn the key for me while I look for spark. Shall update you on wednesday when I find said suitable volunter!
