Elec Ignition Kit For £6.75+vat Found.
#151
Posted 12 August 2009 - 01:06 AM
im about to order 2 kits, but i would like to order extra rotors also for down the road service time
#152
Posted 12 August 2009 - 05:29 AM
#153
Posted 12 August 2009 - 06:16 PM
#154
Posted 13 August 2009 - 08:33 PM
and i went to my local mini shop and ordered plugs,wires,cap
my points went out the other day, so im gonna give this a try and
if it works then good, but if not then i will get new points as they are pretty cheap
#155
Posted 13 August 2009 - 08:36 PM
Have found a landrover parts specialist thats doing an electronic ignition conversion kit for the 45d4 distributors for £6.75+vat. May be of interest to those of you with that dizzy!
http://www.mm-4x4.co...nsor-2721-p.asp
Does this mean I could convert my none electric dizzy to electronic? With out buying a full distributor?
#156
Posted 13 August 2009 - 09:17 PM
#157
Posted 26 August 2009 - 10:08 AM
Are people still finding these kits reliable, or haveing any issues with it?
And is it better to order one over the phone or online?
Chris
#158
Posted 26 August 2009 - 11:08 AM
#159
Posted 06 September 2009 - 05:16 PM
Just used this fantastic quide (in post #92) to fit this into my 1990 auto 998cc. I thought I'd add that I was reluctant to remove the peg, so I filed a slot out of the plate of the electronic unit, so it cleared it. Worked just fine.Right now the one down side, depending what type of points you have fitted you may have to modify the backplate
The picture above shows the setup for a sliding points type dizzy, the bit marked red is a peg which the standard points locate against.To fit the system you need to remove this peg.
On non sliding points dizzys the system should just screw straight on, although I can't confirm this.
#160
Posted 08 September 2009 - 07:35 AM
#161
Posted 11 February 2010 - 01:27 PM
#162
Posted 11 February 2010 - 01:35 PM
#163
Posted 24 May 2010 - 07:47 PM
Its all wired up correctly as far as I can tell black to earth red to the +ve side of the coil. Starter turns the engine over fine but it just wont start did anybody else who has fitted this kit come across the same issue and if so how did you resolve it?
Here is a link to the kit in its current form as you can see they have replaced he rotor arm completely?
http://britpart.com/...soryVehicleRef=
#164
Posted 24 May 2010 - 07:51 PM
Its red to the + side of the coil and black to the - side of the coil, thats why it won't fire.
#165
Posted 24 May 2010 - 07:55 PM
Nope!!
Yeah sorry shifty thats what i meant the black one doesnt go to earth my fault ive currently got it plugged into the connector that the points black wire went to, 99% sure that ends up back at the negative of the coil? Any other thoughts?
