I think a standard 12v coil or lucas sports should work just fine (so long as it's the 12v)
I ran mine on a 9v coil for a while, and it seemed to run OK at first, but has fried the module after a few hundred miles
Was this the issue in newquay?
Ben
Posted 03 June 2009 - 04:38 PM
Posted 03 June 2009 - 07:05 PM
Posted 04 June 2009 - 07:27 PM
Posted 11 June 2009 - 10:00 AM
Posted 11 June 2009 - 10:02 AM
Tried to fit my second one around 2 weeks ago, wired in excactly as instructed, red too coil + and black to standard dizzy earth. Wouldnt start, just cant be arsed with it now, so points went straight back on.
Do you mean you earthed it on the dizzy?
The red goes to + terminal on the coil
The black goes to the - terminal on the coil
Also check the rotor arm is pushed fully home, mine was a very tight fit.
Edit, hello crocks!!
We posted at the same time!!!
Posted 12 June 2009 - 12:58 PM
Edited by Prawn, 12 June 2009 - 01:04 PM.
Posted 12 June 2009 - 01:29 PM
Posted 12 June 2009 - 01:53 PM
Posted 27 June 2009 - 08:42 AM
Posted 21 July 2009 - 12:50 PM
Posted 21 July 2009 - 12:57 PM
Posted 21 July 2009 - 03:07 PM
Doesn't look like itDoes anyone know if the module works with 'impulse' tachos (old style Smiths), resp. if 'impulse ('RVI') tachos work with the module?
Posted 21 July 2009 - 03:21 PM
Posted 31 July 2009 - 11:46 AM
Edited by GreaseMonkey, 31 July 2009 - 11:46 AM.
