Making A Fiberglass Dashboard - Guide
14 replies to this topic
#1 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 31 May 2008 - 09:52 AM
First up i masked off the mini dash area, as if to fill the hole between the dash rails.
I then mixed up the resin and cut the matting to shape, im doing this to make sure the dash would fit nicely when the actual dash is come to fit.
Once the matting was cut to shape i put this in place and applies the resin/catalyst.
I then left this to set and removed it from the mini. once removed i cleaned up the edges of the fiberglass to make it look a bit nice.
I then started to make the different shapes of bits i wanted the dash to have and fixed these in place, i also cut a hole for the glove box.
Once they were all fixed in place i pulled some fleece material tightly over everything and glued this in place. I then applied the resin/catalyst to the fleece material.
Once the resin had set i started to sand back the whole thing.
I then put the dashboard in place in the mini to make sure the fit was good and to see how the gauges would be exactly positioned and they came out exactly as i wanted.
#2 Tomf
Tomf
    Baby Tom
  • 6,440 posts
I continue to sand the dashboard back, i then filled the whole dashboard and sanded back to get smooth.
I then primed the dash, to see if there was anymore imperfections and sanded it back the final time, using finer and finer grade paper.
I then primed again for the final time.
Then i sprayed the dash, its Red as thats the only paint i had lying around that i didnt mind wasting.
#3 mini_lad_1990
mini_lad_1990
  • 614 posts
  • Local Club: aint got one yet!!
Posted 31 May 2008 - 09:57 AM
far enough mate i was thinking about doing this but i might buy one haha
you done a good job tho mate i dont know about the second bump to make the curve but far shout!!!
cheers
#4 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 31 May 2008 - 09:59 AM
Yea i dont really like the look of the dash itself, i made it more for testing out fiberglass and seeing what i could actually do...
#5 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 31 May 2008 - 10:01 AM
Moved to F.A.Q.
#6 mini_lad_1990
mini_lad_1990
  • 614 posts
Posted 31 May 2008 - 03:03 PM
i was looking for this this morning and it disapered haha
you going to keep the dash mate or flog it on flebay??
cheers
#7 kitch
kitch
  • 81 posts
Posted 31 May 2008 - 03:53 PM
Here is my dash made by the same process a few years ago. Yours looks quite good but I would say that you need to fill and sand it alot more to get it much smoother and then it will look perfect.
#8 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 31 May 2008 - 04:07 PM
No i have thrown it out as the finish wasnt good enough.
Yea if i was going to be using the dashboard i would have done alot more sanding and filling before i acctually painted it. but as it was just for my testing i didnt bother.
#9 mini_lad_1990
mini_lad_1990
  • 614 posts
Posted 31 May 2008 - 04:12 PM
i liking this dash i would do it so the clocks was flushed into the dash tho??
also where did you get the switches from cause i been looking for some like that but cant find a 3 click one for the lights??
cheers
#10 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 31 May 2008 - 04:17 PM
Jusy use two switches... one for dip beam and one for main...
#11 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,851 posts
Posted 31 May 2008 - 04:20 PM
you angel!! :)
#12 mini_lad_1990
mini_lad_1990
  • 614 posts
Posted 31 May 2008 - 05:00 PM
good thinking batman lol aint main beam on the stalk tho??
i thought it was dash lights on 1 click with side lights then diped on the second click??
cheers
#13 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 31 May 2008 - 05:04 PM
Yae sorry me just being silly.
Edited by Tomf, 31 May 2008 - 05:13 PM.
#14 Mini Man Dan
Mini Man Dan
  • 1,299 posts
Posted 31 May 2008 - 06:36 PM
Maplins sell toggle switches. Thanks for doing this FAQ Tom, much appreciated!
#15 imaparana
imaparana
  • 580 posts
Posted 21 March 2010 - 07:12 PM
how many layers have you applied and how much resin did you use?
cheers
