Mk3 Mini Cooper 's' Is It Real?
Posted 29 May 2008 - 02:01 AM
it has the square rear lights not like the early cars.
At 1st I thought they didnt make coopers in this year/shape but looking on google I found they made about 1500 odd cooper 's' this year.
My question is, what do I look for to tell if its legit cooper 's' ?
any help would be great!
Posted 29 May 2008 - 08:19 AM
they all had a single body colour with no contrasting roof and the interiors were all plain black vinyl. they do use the basic Mk3 shell with square rear lights and internal door hinges
the VIN code for the MK3 cooper is XAD1 ##### A. ##### represents the build number starting at 34127 and ending at 458987 (other models are included within this range of numbers) the A, standing for longbridge, may or may not be used.
the commission number prefix is N20D #### A. The number range for the com numbers is 101 to 1668
engine numbers should start 12H-397-F or 12H-398-F
all minis at this time are just badged as MINI, the Austin and Morris names were not used on the Mk3 cars although they may be on the log books by mistake.
all cars are made by BL at this time and should have a small BL badge on the A-panels but this may be Long gone
if you go and see it and take photos (front, rear, sides, engine, interior) i should be able to get a good idea from them
EDIT: all Mk3 coopers are "S" type
Edited by THE ANORAK, 29 May 2008 - 08:21 AM.
Posted 29 May 2008 - 09:15 PM
I'm going to look at it saturday now. I'll let you know. It is badged 'morris' which makes me think its definatly a fake one.. i'll check the numbers out anyway..
Thanks for the help
Posted 29 May 2008 - 09:20 PM
Posted 30 May 2008 - 10:24 AM
I dont know what they are going for there, but here its very cheap
Posted 30 May 2008 - 10:32 AM
Posted 30 May 2008 - 10:44 AM
Posted 30 May 2008 - 11:45 AM
Mk3 shell is ok from outward appearances.... wheels and arches are wrong, but does indicate that there's disks behind the front wheels.
Posted 30 May 2008 - 11:49 AM
however, all australian built minis should have been culbman fronted at the time this was made and the Mk2 cooper was replaced by the mini clubman GT. i can find no reference to the Mk3 cooper being made in australia.
this could mean that it was imported from the UK but the indicator lenses would suggest that it came from elsewhere, there were a lot of cars being sold as Part manufactured that would be finished off with local manufactured parts (something to do with import laws i think)
the best thing to do is to find out as much history on the car as you can and see if it rings true, due to the nature of the car it may not be a case of simply going by the UK production records
Posted 30 May 2008 - 11:50 AM
So at what point did the cooper S engine go away from the 9F* prefix ???
12H* is just a bog ordinary solid walled 1275 block
i dont know !!!! i got then numbers from a book, i thought you were the engine number expert
Posted 30 May 2008 - 11:52 AM
Sorry was typing and reading at the same time... and posted before I had all the info... yes I concur the very last of the cooper S block are as you say, never seen one tho' only 9F's
Posted 30 May 2008 - 07:00 PM
Posted 31 May 2008 - 04:44 AM
I went to look at the mini this morning and the owner was pretty dodgy
These are the numbers I got from it.
chassis plate:
XAZS1N / 320104N I think this is what it said.
engine was very hard to read. I got this by the thermostat
OH1509 but could be wrong.. was very hard to read.
The speedo read 140 KMH top speed.. it had a cooper exhaust..
I personally dont think its a cooper as its too cheap..
if someone could look up those numbers i'd be gratefull.
Steve
Posted 31 May 2008 - 04:48 AM
Posted 31 May 2008 - 08:48 AM
I'm guessing that the Z should be a 2 (common mistake) , if so it reads as
X - recorded as non significant but they all have them and on the later VINs SAX is used instead and represents manufacturer's code (MG Rover)
A - A-series engine
2S - Two door saloon (this is the first clue as Mk3 cooper S and 1275 GT should have a D)
1 - Round nose
N - 1000cc (so not a 1275 then)
320104 is build the number
N - this should read A for UK car built at longbridge ??? I cant find any reference to N
well what ever it is, its not a cooper
