I think I have a problem with the crankshaft, basically the end of it appears to be 'pitted',
(the bit where the flywheel goes on that is) and according to mini magazines etc it says that
this is a bad thing.
Does this mean that I'm best off getting a new crank altogether or can I just use this one again anyway.
(I'm rebuilding a 1275 and need to keep things as cheap as possible - I'm a student!)
Picture is attached if it helps, cheers.
