as keen readers will know ive been changing my radius arms over the last few days,
i struggle with access to my mini so i took a spare pair of old arms to exchange against some reconditioned items from minispares,
when i got them home opened the boxes to find to rather rusty unsymetrical arms, (i dont mean left and right handed!!)
one had all new nuts and a shiny machined hub "stud/shaft"? while the other had no nuts/washers and a dull hub "stud/shaft" that i didn't like the look of, however i presumed that one had been on the shelf a while and they had changed the spec at some point,
the one with shiny bits had a horrible 3"long curved bit of steel rivited to it do bolt the brake flexi to where the other had the propper small plate at 90 degrees to the arm, i was pretty annoyed to have to cut that c@#p down to the right length dress it up and drill it myself.
then i got an electric drill and wire cup to clean up all the surface rust (on reconditioned parts?!?!?) and painted them in several coats of hammerite,
i left them to dry and waited for a time i could swap the arms (my car has to be mobile everyday to push it back into storage)
i took yesterday and today off work to fit the arms (it has taken a day a side by the time ive swapped everything over)
when fitting the shaft that had new nuts i tourqued the nuts as per haynes and one split in half! fortunately the shaft was un damaged and i had my old ones so swapped for those.
i filled the brakes up and greased the arms up, or tried. the drivers side (dull hub shaft) went ok and after a few pumps grease cam out of the inboard end of the shaft (none came out of outer end but i presume this is normal?)
the passenger side took for ever and after 5 mins i stripped my grease gun to check for fault, changed the cartridge as this had become empty, tried again and after loads of pumping grease eventually came out of the little shaft that the handbrake quadrant goes onto and no where else!! (yes im certain ive tripple checked)
presumably this makes the shaft a dud? is there anything daft i could have done in fitting?
i am sure mini spares would have swapped the arm but it is now painted red and is all built up, i will have to find time to get at the car again and time to get to minispares.
i presume this will be another case where the customer looses out ie its cost me in paint, grease, split pins, lock nuts, £20 in petrol to harrogate from me and god no's how many days it will take. (everything ads up!!)
the biggest annoyance is its probably added a month to my nearly complete project
i am not happy to say the least.
I am a Plumber/heating engineer by trade and a situation like this costs either my firm or the supplier the customer never ends up out of pocket.
i pray that someone will tell me its me being stupid or something ive done wrong but i think its highly unlikely
has anyone else had similar problems?
moan over!!
