Okie doke while I have a spare 5 Min's waiting for a callback from a supplier I may as well put up a proposed spec.
Strip back to bare shell.
Replace any goosed panels & chop out and replace any tin worm etc.
Fit turbo bulkhead box.
Full in & out respray.
Very comprehensive rust protection scheme!
While in pieces everything is going to be inspected & if required reconditioned or replaced.
Looking for a quite subtle finish so was thinking.
Exterior
Tartan Red with Black Roof
MPI roof Aeriel
Black 12" Revo's with Yoko'sBlack Rover Minilites with Yokohama A048R Tyres
Wood & Pickett Style Arches
Body Colour Wing Mirrors
Body Colour Rear Number Plate Light
New Cooper Grille & Surrounds
New Genuine Bumpers
New Door & Boot Handle Set
All new seals (door, boot etc)
All new chrome work
Halogen Headlights
Clear Indicator Lenses & Side Repeaters
Clear Rear Lenses (fog light moved into o/s reverse lamp)
Winged bonnet & boot badge with black Turbo insert
Welded up LHD wiper holes
New Genuine wiper arms & washer jets
Interior
1995 Cooper big bolster front seats with matching rears and door cards
Brushed Alloy door furniture
Moto Lita John Cooper signed leather steering wheel
John Cooper alloy gear knob
Steering column lowering bracket
Digital clock in upper dash rail ashtray slot
Burr walnut dash with 3 aux gauge holes.
Magnolia Clocks
52MM Boost PSI, Oil Pressure & AFR gauge's
Grey fabric headlining from Mini 35
Black deluxe carpet set
ICE
DVD/MP3 Head Unit (Undecided On Make/Model)
JBL GTO327/427's in dash (welding up fresh air vents in shell)
JBL GTO 936's in rear shelf
May Use 4 Channel Amp I have laying around in garage.
Running Gear
Standard MG Metro Turbo Bottom End
N/A MG Metro Camshaft
Duplex Timing Gear
Modified Hi-Boost Cylinder Head
Jack Knight 4spd SC/CR Box
Jack Knight 1:1 SC Drops
X-Pin Diff with 3.2 FD
Modified Plenum with DV
Escort RST S2 Intercooler
Megajolt Ignition
Modified Ex Manifold
Enlarged T3 Elbow
STD Metro T3 Turbo
Avonbar Billet Actuator
Pre-Verto clutch & flywheel setup with Grey/Double Grey Diaphragm
Maniflow Turbo Downpipe
Maniflow Turbo Exhaust System
Playmini 3" Stainless back box
Minispares 2 core radiator
Wide blade fan
Aux fan on inner wing connected via thermostatic switch
Fully rebuilt braking system using vented Metro 4 pots
Remove servo in favour or additional space under bonnet for Intercooler etc
New uprated/poly bushes all round
GAZ adjustable shocks
Adjusta-rides/Hi-Lo's
Adjustable Tie bars & Bottom Arms
Adjustable Rear Camber/Castor Brackets
I'm open to comments suggestions from anyone!
Edited by minimadmotorman, 10 November 2008 - 09:46 AM.
