clutch release bearing
6 replies to this topic
#1 Purple Tom
Purple Tom
  • 4,921 posts
Posted 22 May 2005 - 10:54 PM
Hi people
I'm replacing my clutch on saturday, and will be doing the clutch release bearing at the same time. How does it come off the flywheel cover, and how do I replace it? Its a verto clutch.
thanks very much in advance
Tom
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 May 2005 - 06:31 AM
Fortunately a verto is slightly easier than a diaphragm...
I'm not sure you even have to remove the plunger from the bell housing..
Here's what the manual says...
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 May 2005 - 06:34 AM
Quick pickie...
12 'O' Ring
13 spring retainer
14 Bearing
15 bearings retainer plate
17 Plunger
Edited by GuessWorks, 23 May 2005 - 06:38 AM.
#4 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 23 May 2005 - 06:36 AM
it's really simple, did one the other day when fitting the replacement engine! The o ring just comes off with a screwdriver and then you lift it off! replace it and the put the o ring back on! bob's your uncle! :cheese:
#5 Purple Tom
Purple Tom
  • 4,921 posts
Posted 25 May 2005 - 10:05 PM
sorry I forgot I posted this thread, only just remembered!!
Thanks very much for the advice, thats what I did in the end!! ;)
Tom
#6 Cir-clipalot
Cir-clipalot
  • 310 posts
Posted 25 May 2005 - 11:20 PM
you mean refitting ISNT the reverse of removal?!? an unusual diversion for mr haynes...
#7 MiniMenzies
MiniMenzies
  • 190 posts
Posted 24 May 2012 - 07:43 PM
Sorry to bring this thread back up but how tight is the fit between the release eating and the plunger because I can rotate it about 20 degreese?
