Here we go:
Bill Richards 1380 cc road/race offset bored and decked A+ block (no idea of compression ratio yet)
73.5mm forged pistons which Bill machined lighter
Miglia spec con rods lightened, balanced, shotpeened and polished
Turbo crank, nitro carburised, wedged and cross drilled, centre main strap fitted
Race/rally head 36/31 mm waisted stem race valves, piper retainers and springs, titan full roller rockers
kent 288, piper vernier timing gears
weber 45 DCOE on maniflow steel inlet
Maniflow twin box race system with phase/stage 2 maniflow LCB
cometic triple steel shimmed head gasket
Megajolt with KAD timing wheel kit and custom made magnacore HT leads
Hits 8k rpm no problem
Gearbox etc:
AP racing clutch plate, orange diaphragm, ultralight steel flywheel
Minisport SC drops
Minisport SCCR gearset
Minisport 4 pin diff
Oil cooler
alloy rad
minispares toothed belt kit (alternator, crank, water pump)
Acheived 96.3ft/lb and 110bhp at the fly running on twin 1.5 SUs and no megajolt,
With weber and megajolt hopefully 100+ ft/lb maybe 110/115 ish bhp
future plans:
M45 supercharger (decompression plate due to head CC's)
or
Honda B16
Edited by spikyrob, 18 February 2009 - 08:09 PM.
