What Spec Is Your Engine?
#91
Posted 31 December 2007 - 12:00 AM
1.75" HIF44 Carb running K&N filter(soon to be twin hs4)
fully worked race head
1.5 ratio minispeed rockers
maniflow Inlet with k+n cone
maniflow stage 2 with rcm
unkonwn cam, kicks in at 4k
84mm crank, unknown work
pre verto clutch ultra light flywheel orange dia paddle plate
unknown gearbox(soon to be doggy style!!!)
0-60 ? speedo not worketh correctly
0-100 ?speedo not worketh correctly
bhp ? r/r coming up soon
#92
Posted 31 December 2007 - 12:16 AM
998cc
2.9diff ratio
1.5'' carb
lecy ignition
lumex ht leads
no a/f
lcb
straight pipe 1.75'' bore(that hits the gearlinkage really bad)
centre box of a deisel rover as back box(dead noisey, lovely)
metro inlet manifold
running 1300 head till i finish other build then it will be going on that
future mods
1330
piper 295
duplex chain
centre oil pick up
polished + ported head, skimmed about 30thou
block deck bout 5 thou
lecy fan
two rad
extra front mounted moped rad
10 or 13 oil cooler
standard
rods
water + oil pumps
metro box and 3.44 diff
roller rockers
will be running a hotter or a colder plug cant remember at the moment to late at night
thats all for now i think
Edited by just_jack, 05 March 2008 - 10:37 PM.
#93
Posted 31 December 2007 - 06:08 PM
1275 block +.020 omega pistons
scatter cam
Massivly moddified 12g940 head, 28/37mm valves, port matched manifolds. 11 stud conversion
weber 45dcoe on long manifold.
sccr box
sc drops
Plate diff (a nightmare)
was rolling roaded on a Turbominis rr day and did 86.5 at the wheels after being laid up and not used for 5 years.
Engine was built and raced by Mike Barrett of MBE in lincoln
#94
Posted 03 January 2008 - 09:13 PM
#95
Posted 03 January 2008 - 09:28 PM
Swiftune rods
Turbo crank x-drilled, wedged, backdrilled and bladed
310 x-drilled billet scatter cam
1.5 full roller rockers
Swiftune full race head 37.5 x 30
45 DCOE
Maniflow st2 extra large bor LCB
Swiftune dogbox
Salisbury LSD
SC drops
etc
etc
In the car gives 320 bhp per ton
Paul
#96
Posted 04 January 2008 - 01:10 PM
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/unsure.png)
Plans afoot for a 1380 build:D
#97
Posted 04 January 2008 - 04:55 PM
998 a+
68 mm forged pistons
850 crankshaft (heat treated, balanced and cross drilled)
Piper BP300 (312 degree or rotation) power band will kick in at about 3300
1.3:1 lightened and strengthened
Benross head, full elbow and port work, 36mm inlet valve and 30mm exhaust valve, 21 cc chambers.
2x Yamaha R1 carburetters
Maniflow stage 2 large bore long center branch manifold and exhaust system.
Grey clutch.
straight cut drops
low mileage 998 gearbox.
Ford edis ignition system coupled to a mega jolt unit.
compression ratio will be able 11:1 and will be 990cc
Edited by flyingears2002, 04 January 2008 - 04:56 PM.
#98
Posted 04 January 2008 - 04:59 PM
better add what mine is anyways.
1293 over bored.
stage 2 head, standard rockers.
stage 2 maniflow full exhaust
vizarded hif carb.
Edited by Matt, 04 January 2008 - 05:04 PM.
#99
Posted 04 January 2008 - 07:57 PM
I currently have four enignes...
Flubber the '67 Van;-
- 1275 offset overbored to 1380cc
- Stage 4 Rob Walker head
- Twin HS4 carbs, on a Maniflow inlet, and RAMAIR filter system
- 1.5:1 Swiftune Roller Rockers
- SW5-07 Camshaft (set at 107degress)
- 9.6:1 Compresstion ratio
- Adjustable vernier lightened duplex timing gears and chain
- Powermax 73.5mm pistons with a 7cc centre dish
- Lightened and balanced A+ Conrods
- A+ Oil pump
- Ball and spring oil pressure valve
- Brand new A+ 1275 Crankshaft (Balanced)
- Lightened 11lb flywheel (steel)
- Orange diapham pre-Verto clutch
- Standard Helical transfer gears
- GT gearbox, with a 3.1 final drive
- Aldon Yellow electronic dizzy
- NGK Sprak plugs
- Maniflow phase 2 medium bore LCB
- Maniflow twin box 1.3/4" exhaust system
- 10row oil cooler
- 7mm Silicone ing leads
Voodoo - currently there are 3 engines for this little beasty...
Current engine...
- Completely standard A+
- exSPi engine running on A+ Metro electronic ingition
- Twin HS4 carbs
- 10.2:1 Compration Ratio
- 1275
- stage 2 head (homebrewed)
- 10.5-11:1 comprestion ratio
- Standard pistons
- Standard rods
- Kent 286 scatter camshaft
- Duplex timing chain and gears
- GT gearbox with a 3.44 final drive
- Turbo Vetro Clutch and flywheel
- Honda Civic Type R engine
- 2.0litre
- 16 valves
- i-Vtec technology
- 6 speed
#100
Posted 13 January 2008 - 12:06 AM
bigging up the old topics
998cc
3.1diff
1.5'' carb
lecy ignition
lumex ht leads
no a/f
lcb
maniflow centre exit stainless roll out 2'' bore
future mods
1330
286 scatter or equivilent
duplex chain
centre oil pick up
polished + ported head, skimmed about 50thou
block deck bout 5 or 10 thou
lecy fan
twin core rad
10 or 13 oil cooler
high capacity water + oil pumps
standard
rods
metro box and 3.44 diff or stick with the 3.1
roller rockers
will be running a colder plug
only half the parts half come that i ordered so the one litre has got the 1300 head with double valve springs on it and well soon be getting the cam
but then when rest of parts get here 1330 will be in
Edited by just_jack, 14 January 2008 - 10:14 PM.
#101
Posted 13 January 2008 - 12:16 AM
future improvements
2.0 ltr Vauxhall Red Top
Edited by minimad998, 13 January 2008 - 12:17 AM.
#102
Posted 07 March 2008 - 10:50 AM
Powermax +.60 thou pistons
1275 Cooper S gearbox with Comp pick up pipe
X pin Diff
Nitrocarbunised Crankshaft
Mild Road Cam
Metro Turbo Head bored out by 30 cc
36.5mm Inlet valves
32mm exhaust Valves
Eaton M45 Supercharger
HIF 44 Carb
K & N Filter
Metro Turbo stage 2 clutch with AP Racing Plate
Just being finished, had a crack in the last cylinder head so just had a new one put on, hopefully back next week!
#103
Posted 07 March 2008 - 11:14 AM
1071cc 's' motor
Weber 40 on 3.5 inch manifold
Oselli OE62 head 36x31 14.4cc chambers, 12-1 CR
Lightened and balanced end to end
Ultralight fly and backplate
Grey clutch and AP 'rally' friction plate
Re-ground and re-hardened 's' crank
Swifty SW10 cam
1.08 ratio s/c drops
S/c clubman gearset
X-pin diff with 3.6 FD (equates to 3.9 with drops)
Maniflow stage 2 LCB with twin box centre exit system
83bhp at the wheels
A cracking motor with a mad rev limmit, not as useable as something like a 1380 tho as it requires you to drive everywhere with your foot firmly welded to the floor. Massive fun tho, even with the lack of torque.
Just for anyone to referance seeing as 998modding is becoming popular....my old motor
998cc pocketed
12g940 head
twin 1 1/4 carbs
286 cam
lightened verto fly
GT gearbox
4.1 final drive
64bhp at the fly
IMO it was over cammed for the spec of the motor. Had much more potential if the assembly was lighteneed and balanced, also should have honed and re-ringed the block... If your thinking of doing the same either use a slightly tamer cam, or make sure the top end is perfect and possibly a weber, you'll see 70+
Edited by JetBLICK, 07 March 2008 - 12:22 PM.
#104
Posted 07 March 2008 - 11:16 AM
+0.020 Forged pistons
Wire ringed block
Ultra light steel flywheel
Ultra light steel backplate
4 Padle sintered clitch plate
Double grey diaphram
Rods have been releived and shot peined
11 stud block & head
4mm solid copper head gasket
Metro Turbo Challenge cam
Vernier adjustable duplex
the head is depeaked
Cosworth double valve springs
Modified rocker posts to clear the valve springs
lightened pushrods
STD ratio forged rockers
4sp SC/CR gearbox
SC drops
Twin crosspin diff
Central oil pickup
Metro turbo challenge carb, extensively modified
T34 Turbo
Fuel injector that cuts in at high boost
139bhp @ 11psi flywheel
115bhp @ 11psi Wheels
22psi = broken gearbox but loads of fun
Edited by mini_turbo_pete, 07 March 2008 - 11:24 AM.
#105
Posted 07 March 2008 - 11:46 AM
Hydraulic verto clutch conversion
Custom Metro/Smart driveshafts
Custom short LCB, flexi-pipe and RC40 single box system
HIF44 with Piper stub stack and K&N Land rover filter (cold air feed)
Electric water pump with front mounted rad & electric fan
Reversed gear linkage with reversed gate seletor box
Modified breather system
Electric fuel pump
