What Spec Is Your Engine?
#46
Posted 19 July 2005 - 07:49 PM
- 1300GT solid wall A series block bored to +.060
- 21253 HC cooper pistons rising just proud of block deck (11-12:1 CR unverified)
- 1300GT 11 stud head, 1.4" inlet 1.1" exhaust bronze guides std rockers, cleaned up ports and combustion chamber ( probaby equiv to stage 2 )
- Tuftrided crank
- Ultralight billet steel flywheel & Back plate
- Early Kent 290 cam timed @ 105 degrees, fully adjustable vernier silent chain timing gear.
- A series helical drops.
- A series Close Ratio GT gearbox with 3.44 CWP on a X pin Diff.
- HIF44 with modified BBC needle 8 oz spring and K&N
- Phase 2 Maniflow LCB hooked to 1.3/4" single box RC40
ooh.. forgot about ignition..
- lucas sports coil
- BP7ES plugs
- Modified Aldon 100AY dizzy, using sliding points and vacuum advance.
30 miles old, and doing the 1/4 in 16.45 on std 145/70x12's
Needs a tune and probably capable of going sub 16 for the 1/4.
#47
Posted 26 July 2005 - 08:29 PM
+ K&N air filter, dunno whether it worth it buying an rc 40 2.25"
#48
Posted 26 July 2005 - 08:45 PM
LCB, K&N cone, cat removal, single box rc40
#49
Posted 26 July 2005 - 09:35 PM
#50
Posted 26 July 2005 - 10:14 PM
#51
Posted 12 August 2005 - 02:52 PM
#52
Posted 14 August 2005 - 11:09 AM
#53
Posted 24 August 2005 - 03:31 PM
#54
Posted 24 August 2005 - 05:35 PM
Stage 1
Single box rc40
Additional fan on switch.
#55
Posted 24 August 2005 - 06:39 PM
#56
Posted 26 August 2005 - 07:25 AM
Thats about it
#57
Posted 06 September 2005 - 07:34 AM
#58
Posted 06 September 2005 - 08:52 AM
#59
Posted 06 September 2005 - 09:29 AM
It'll have about 80-100 BHP
#60
Posted 13 September 2005 - 11:33 AM
1275 Block bored 20 thou
Reground and tuftrided crank
Cooper S conrods
AE Hepolite Pistons
Turbo Oil Pump
Spam 28 Camshaft
Stage 4 Head (Big Valves
1.5 Roller Tip Rockers
Central oil pickup
3.7 Diff
Maniflow Big Bore Manifold
RC40 Single Box
HIF44 Carb
Should put out about 85+BHP Hopefully
