What Spec Is Your Engine?
#151
Posted 07 August 2008 - 10:51 AM
#152
Posted 07 August 2008 - 02:10 PM
I love it, but it does mean that your screaming the nuts off it at 60mph.
5300rpm at 70 for me.
#153
Posted 07 August 2008 - 02:20 PM
#154
Posted 14 August 2008 - 02:04 AM
998cc
stage 1 tuning ( needle...kn filter...lcb and centre exit dtm)
silicone ht leads
#155
Posted 25 September 2008 - 09:08 PM
im guessing he means putting the whole crank rods and piston aseembly straight in, its a straight swap, swiftune do forged ones for the 1098998 forged pistons
where where where!
#156
Posted 26 September 2008 - 10:52 AM
Standard 1275 Mpi Block
John Cooper Stage 3 Head
1.5 Roller Tip Rockers
S Works Polished/Ported inlet manifold
Uprated alloy throttle body
Janspeed LCB Exhaust Manifold
Janspeed DTM System when new, now Playmini full stainless
Modified S Works Filter Box with K&N Element
Vernier Timing pulley + Belt Drive
Uprated Mpi Cam
Superchip Icon
Jack Knight 5 speed box with X pin diff
90bhp when bought new from John Cooper Garages, current bhp after non JC extra's added, not confirmed.
#157
Posted 26 September 2008 - 10:55 AM
848cc with 185k no bottom end rebuild!
Competition Car
998cc with stage 1 kit
#158
Posted 26 September 2008 - 10:56 AM
#159
Posted 26 September 2008 - 08:51 PM
soon going onto r1 bike carbs and mega jolt. wish i had kept those buggers now. 118 at the fly wheel (confirmed from engine dyno).
with the bike carbs and mega jolt im hopeing for 100 at the wheels.
Edited by flyingears2002, 26 September 2008 - 09:12 PM.
#160
Posted 26 September 2008 - 09:00 PM
998 +20
Flowed 12G295
Lightened flywheel (to get)
Megajolt ignition
S/C drops
HIF38
Morspeed PH2 camshaft
Duplex timing chain
Electric fuel pump (to get)
3.44 FDR
Freeflow manifold
And a BLUE rocker cover
No idea at all what the output will be, but over 45 at the wheels is plenty for me.
#161
Posted 27 September 2008 - 09:14 AM
makes me want to build a shortened stroke 998
custom grind cam, the bp320 isent lairy enough for an engine capable of 10000 revs really. but you cant go much more then that unfortunately.
#162
Posted 27 September 2008 - 11:12 AM
12G295 Head
Forged Rockers 1.3 ratio
Twin HS2 with custom ram pipes
Freeflow Manifold
SS Twin box RC40
3.44 FDR
Lumention Magnetronic ignition
#163
Posted 09 December 2008 - 01:16 PM
was a standard mpi engine 1275, now.....
MED road comp head (stage 3/4)
1295 block, new pistons rings etc...
Swiftune sw5i cam
1.5 high lift roller rockers (swiftune)
Duplex vernier timing kit (swiftune)
Rebuilt gearbox with central pickup
3.44 fd
s/c drop gears 1.1
New bearings all round (gearbox and main,cam bearings)
Janspeed LCB with relocated lambda
Maniflow de-cat
Maniflow cat-back twin box 1.75"
K&N 57i kit
Polished and gas flowed custom manifold
52mm Burlen Throttle body
Forge fuel pressure regulator
MPI high capacity front rad
oil cooler
KAD quick shift
think thats it. Couldn't believe it started nearly first time (after my Haynes told me the wrong way round with my HT leads)
Havent had a chance to see what its putting out, but the closer to 90bhp, the better. Cant wait to see the torque its putting out.
Anyway, thanx
Edited by tony kenobi, 09 December 2008 - 01:17 PM.
#164
Posted 23 December 2008 - 12:34 PM
73.5mm bore
powermax 9cc dished pistons
balanced crank
10thou crank regrind
kent 286 cam
Big valve head
Hif44
lcb
2" bore centre pipe
dtm twin exit back box
standard box
hardened diff pin
I dont know what the final drive is.
My 998 pretty much standard
dished pistons
standard cam4810 head
cone filter
lcb
dtm back box
42hp at the flywheel
#165
Posted 23 December 2008 - 12:46 PM
53HP SPI cam
9.4:1 CR
HIF44 w. MG Metro manifold
Medium bore LCB
RC40 twin box
K&N in Cooper RSP airbox
64DM4 RSP Cooper dizzy
3.11:1 FD
Perfect engine for cruising,
bit weak for uphill-'racing'.
Runs fine with a BAP needle.
Edited by Asphalt, 23 December 2008 - 12:47 PM.
