Setting Fuel Pressure Regulator (how to?)
2 replies to this topic
#1 1275MIN
1275MIN
  • 130 posts
Posted 22 May 2005 - 06:58 PM
Can any one give me a clue on how to set up a new fuel regulator on an engine that has not been run yet, to get the engine running and then to set it properly? Thanks :lol:
#2 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 23 May 2005 - 05:17 PM
you'll need a fuel pressure gauge, i use a "gunson lo gauge" about £15 from halfrauds.
take the fuel pipe from the reg to the carb and disconnect it from the carb. stick the gauge on the end, switch ignition on so that the pump is running and check the pressure.
to adjust it undo the locknut on the regulator and screw it in/out untill you get to roughly 3.5psi. anywhere between 3 & 4 psi is fine.
thats it, it wont need adjusting when the engines running properly as it does it itself. if you want to check the reg is working then T piece it into the fuel line and wedge it under the window wiper, take it out for a spin and watch the gauge.
if you set fuel pressure @ idle to 3.5psi then running 10psi boost it should show 13.5psi fuel pressure, it should always stay 3.5psi above boost pressure basically.
Nick :lol:
#3 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 24 May 2005 - 07:36 AM
Yep ! Bud's right. Here's a picture of the gauge you need - fuel pressure gauge
Phil. :lol:
