Track Car With An Mot
#31
Posted 31 January 2009 - 11:51 PM
Keep up the good work.
#32
Posted 01 February 2009 - 12:18 AM
looks great from what ive been told the quick shifts all seem to get a bad press as make it hard to select gears "apparently" the one on mine was removed after 2 weeks as drove the pre owner mad so im happy to live without one onyl think id advise is the spring bias that makes the gear selector return to middle so making a quicker smoother 3rd change
also you dont want to have to strip the box after 4 races as you muched the syncros to death lol
gonna be nice on the cylinder head front there still a small edge / lip on the inlet port that would annoy me and id keep an eye on the cylinder head cracking between the 2 valves as they seem awefully close as i say id just make sure to inspect the head every year to make sure its not trying to crack there especially with the heat the head puts up with when racing have you got an oil cooler as i would deffo advise this and also if your gonna spend money on a good gearbox dont forget a center pick up pipe and id even molly slip the box as this coats the gears in grafite and protects them and strenghtens / lubricates the syncros
happy racing
#33
Posted 01 February 2009 - 09:53 AM
Cheap kits will be nothing but trouble but if you buy the KAD kit, you will be just fine... you get what you pay for.
I'd even molly slip the box as this coats the gears in grafite and protects them and strenghtens / lubricates the syncros
Forget it,... the amount of time that Oil companies go to formulating the oil to do the job it's designed for is phenominal, there are a tremendous amount of detergents and lubricants already,..... for someone to come along and add stuff to it often just causes more problems.
Better to buy the best oil you can get your hands on, Penrite is recommended,.. and keep up to date with regular changes, servicing and maintenance.
#34
Posted 01 February 2009 - 11:36 AM
#35
Posted 01 February 2009 - 11:56 AM
#36
Posted 01 February 2009 - 12:05 PM
#37
Posted 01 February 2009 - 12:08 PM
coolio i have just heard from a guy whos been running a mini 1340 with moly slip in the box for years with no issues at all so i was advise to by the lecturers at my college who've been in the trade for 14 yrs so i believe them with the moly slip front
problem of mini's sumps sharing engine oil though, if you alter the oil thish is designed to prolong bearings in this type of system you could be doing more harm than good, gearbox's arent weak things where as bearings are
#38
Posted 06 February 2009 - 01:24 PM
#39
Posted 06 February 2009 - 02:37 PM
rob
#40
Posted 06 February 2009 - 05:01 PM
hi, dose anyone know about a KAD internal gear linkage kit??
hi, i have an internal gear linkage, mine was off a miglia and works faultlessly so i would presume a kad kit would only be better
rich
#41
Posted 06 February 2009 - 05:48 PM
does anyone know how to make 1 of these??
#42
Posted 06 February 2009 - 05:52 PM
also it pays off alot by solid mounting the bottom of your gearbox, to the rear, stop as much movment as possible really. heard stories of them popping out of gear
#43
Posted 06 February 2009 - 09:42 PM
Edited by foodboy, 06 February 2009 - 09:43 PM.
#44
Posted 15 February 2009 - 02:39 PM
rear beam and rear brakes are on, pedal bok is on master cylinders are on rear coil overs, and my tank is finished so that is placed for size.
its coming along now just need to get the big brakes sorted.
Edited by foodboy, 15 February 2009 - 02:40 PM.
#45
Posted 15 February 2009 - 02:53 PM
Question though... how do you mount the studs in the rear hubs?
